Took the ol FJ60 to attempt a smog this weekend. HC & CO levels failed miserably. Mechanic did some testing and was able to lower the readings by pulling the air cleaner off the carb and covering the carb intake. He is suggesting pulling the carb off and breaking through the anti-tamper to adjust the air/fuel mixture screw. Do you guys think this is a bad idea? He seems pretty convinced he can get it to pass smog by adjusting that.. I'm a bit hesitant giving him the go ahead because I read on mud that adjusting the air/fuel mixture should be the option after exhausting all else.
