- Thread starter
- #21
All spots where I wanted to screw something on to later, I added flanged stainless steel nuts that are normally used for welding and inserted them flush to the panel from the opposite side.
With a thread of M6 (6mm metric) they are about 8mm long which will work fantastic with 10mm plywood recessed abotu 1mm deep. If I remember right I used about 80-90 nuts of this type.
Furhtermore, the evaporator and compressor of the fridge need to get some cool air from the cabin so I came up with a honeycomb pattern in the sidepanel.
Because I was weakening the plywood near to the edge, I added some U-shaped aluminum profile to the end of the sidepanels.
) but am working in the plant engineering field at the moment - which is kind of big luck for my LX build as I have access to a whole factory in terms of materials, space and also machines to use for the metal work and maintenance of the cruiser.
