So I did get to around 45F. After re vacuuming and charging. Used a new: yellow hose and 134a resealable can tap. At first I got the same (52F) then bought new thermostat and saw improvement. But still not 45F or less. Then I add 3 more oz of 134a. Tmep hot ~43F. Seems I was underfilling, by using 316oz12 oz cans. Likely due to loss while bleeding air from H & L lines to manifold and bleeding yellow between can swaps..
Now that COLO requires reseal cans. I can easily stop and store partially used cans.
~45F actually saw it hit the green (~44F) at L35PSI H220PSI
Sorry 16os, was a typo. 3x 12oz = 36oz. So I've estimated 37oz -+1oz. IIRC: 36 oz is only just above minimum capacity.
Pick this NEW Yellow Jacket 49967 Titan up today $160 plus taxI'm pretty sold on the 49967 set. It is a good quality analog set with all the features you might need.
To go 'up' from there, you are talking the newer digital sets that can run well over $1K
A good manifold set with good hoses and a 'good' 2 stage vacuum pump is all a person needs to get started IF servicing vehicles for a living. The DIYer/home mechanic that works on systems infrequently can do with less of course.
Most sets don't include the High/Low side connectors....as there are different styles and folks like to choose their own. Don't scrimp there and create a weak link in your equipment.
Yellow Jacket 49967 Titan Charging Manifold 4-Valve w/ Sight Glass & 3-1/8 Gauges 4 Hoses
Shop Yellwo Jacket HVAC Tools. Number 49967. Titan Charging Manifold 4-Valve with Sight Glass and 3-1/8 Gauges 4 Hoses. McCombs Supply Co. Fast Shipping!mccombssupply.com
Oh NO! I just look to see the 49967. Now I see the listing heading states 49967, but picture of box shows 49867.Be sure to get a set that includes R134a.
Yellow Jacket 49983 TITAN 4-Valve Test and Charging Manifold 3-1/8" Gauges (psi, F) for R-22, R-134a, and R-404A
Is it just a matter of using/getting R-134a hoses for the manifold?
