replaced wheel bearings, universal joints,
trying to find hub boot
does anyone know if the older Toyota's parts would fit this
Also, two suggestions.
1. Post this up in the diesel section. I did a quick search and the Blizzard has been discussed.
2. If you have the VIN Toyota will support this vehicle ... assuming parts are still available. But your local dealer will probably blow you off. Talk to @beno (Onur) here on MUD. He loves finding parts for $hit like this.
Finding parts for this Diahatsu made Toyota isn't easy
If you need to see pics of this blizzard wagon look in my previous messaged
my '88 blizzard looking to build it up
It’s a nice looking blizzard, did you have any luck with locating parts.
I have small issues, fuel pump gasket, steering column upper & lower bearings, left front wheel bearing & hub boot,I got lucky it is almost like original when it was shipped from Japan. The guy I bought it from shipped over here.
I have his paper work and all. I have to drive it dayly it's my only car. I'm not much of a mechanic. I couldn't begin
To take on a rebuild like the one your getting ready for. Good luck if I come across anything I will let you know.
1992 Daihatsu Rocky | eBayNice to see this... I've been thinking about picking up a Rocky![]()
Took a little time to think and decided to replace the engine on my 1988 Blizzard Wagon, i'm putting a VW 1.9 TDI ENG, stock it has 175hp, it'll be completed within the next 6 weeks or so.I have small issues, fuel pump gasket, steering column upper & lower bearings, left front wheel bearing & hub boot,
I bought mine in northern Oregon, it was also shipped from japan
