- Thread starter
- #121
Hm not sure. I just remembered how spiffy springs look repainted. Chicago did it with his SOA build-up.
Thanks, I will do some searching and see what I come up with. Never did read all of Chicago's SOA thread.
Well you have inspired me to go out and get some work done on mine today, thanks. I was looking over my parts cruiser (the one I am taking the frame from) and I can't seem to locate the access hole for the furthest reward cab mounting bolt. It looks as though it should be just inside the tail gate but I can't fine it, I will post pic's of the "area" when I remeber to take my camera with me, please let me kow if you know about the one I am talking about.
I took off the spring pin and shackle bolts as well. As with most of you, none of them want to budge. I don't have a torch, so I am thinking of cutting the pins as I will have to buy greasable for all anyway.
You could just cut the spring wrap with a grinder, since your putting on the new lifted springs.
Not sure which access hole you are talking about. If you are talking about the bolts from the body to the frame, I did not have to "hold" them from the top get the double nuts off. I haven't done anything on the inside except for the shifter plate.
I wish I didn't have to hold mine from the top. I was able to remove the jam nuts (one of the two nuts on the body mount bolts) without any issue but when I try the other one(s) the bolt just spins. I am thinking of just cutting with the sawzall but I may get a helper to hold a wrench on the bolt head while I crank on the nuts from below.... this still leaves me with the problem of those rear bolts, like I said I can't figure out where I am supposed to access those, guess I'll burn that bridge when I can't get any further.
Got some time in today and I found the access panel for the furthest rear cab mounting bolts. If you get under the truck and look from the front at the bolt and then look above it you may (or may not see depending on how much rust/dirt there is packed up under there) see two philips head srews holding a cover plate on. I have not gotten mine off yet because I wanted to soak it in PB blaster before I strip the heads off. I may just drill the heads and then replace with socket head cap srews, we'll see how it goes. Anywhoo heres what it looks like. Can you say RUSTY!
It looks like I am going to pick up a puller tomorrow. After spending hours burning bushings and some serious beating I still dont have any bolts out. Thanks for the tip!
