Builds ?????????80 tm Build Input Requested (39 Viewers)
Use a hole saw in the outside and inside of the frame to be able to weld the old frame to the sectioned in tube, this will give you a lot more weld than trying to rely on spot welding through the frame.
Went to talk to a guy that helped straighten bumper yesterday, laid out plans, and concern was expressed over the entire idea, mostly due to moving the location back past where the frame turns up, to get a 12" piece in.
He's hanging out a shingle June 1, so going to wait until the move, consider all other options between.
Love that brown leather!
Ain't it nice?
Folks compliment more the leather than all else. Hahaha.
I've got concerns about this as well Chris. You want to keep it as original as possible but this will make the truck a salvage title. Surely theres a better solution.
Be Lori's problem. Haha.
At the absolute very least, would want to move the rear cross to near the edge of the door, something I can do pretty easy....but feel I'm succumbing to mediocrity.
Time to ponder.
Shocks specs sent, a big milestone. Keep pondering the balance.
After a year of talking about it, Radflo's finally ordered.
For posterity:
Rear Pin to Eye
762mm (30") extended
460mm (18") compressed
300mm (12") shock travel
616mm (24.25") Ride Height
Resi fitting exits shock body at 90 degree angle, parallel with shock body, attaches to 14" long hose, and enters the reservoir straight. Mount to inner rail.
Front Pin to Pin
768mm (30.23") extended
455mm (17.90") compressed
313mm (12.33") shock travel
635mm (25") ride height
Resi fitting exits shock body at 90 degree angle, parallel with shock body, attaches to 10" long hose and enters the reservoir straight. Mount like MTs.
Excellent, looking forward to install dissertation, fork test dissertation, first run dissertation....
Hahaha
Seriously though, look forward to it all. Definitely has been helpful to me thus far.
After many months, maybe a year, still don't feel it's right.
Best I can tell, the coils must be providing closer to 5.25-5" lift.
The accurate comparative measure is hub to flare, right?
I think it goes something like this
What is a stock spring hub to flare measure? anyone?
The reason I am asking is because I bought my'96 with a lift already installed and I have 25" both in the front and rear from hub to bottom of flare. So I wanted to know what stock measures were so I know how much has it lifted.
