- Thread starter
- #1,301
You going to use the box as parking blocks?
Ha.
Master cylinder and few other incidentals.
Along with the window runs I ordered, shocks, spare cover, FJC LT CV axle swap and wheel bearings, I'm tapped out.
Will "bedding" now require new pads?
just search for bedding brakes here on MUD and go out and do it
And yes, Claudia drove the '80 when we did that...![]()
I have the feeling this phrase will see a lot of use in the not too distant future...![]()
I assume you did bleed the LSPV every time in between each caliper ?
She doesn't do the stuff under the truck... I'm the one who gets to crawl around under there.
Recently I removed the front calipers to replace the brake lines. Upon assembly and attempting to bleed the brakes I was met with constant let down every test drive with air in the system. I pumped about 3-4L of brake fluid using every bleeding trick in the handbook and must have bled each caliper 10 times minimum, all without success. I couldn't believe it as I'd bled these brake, and other vehicles, several times before without issue.
See, the main problem is that air bubbles can remain trapped or hidden in the system and even if you pump the pedal 20 times, air can still be trapped. And with the one man bleeders, it doesn't take much for the res to need emptying. I then found myself in the hardware store and happened to see a heap of plastic tube. One particular tube was 5mm dia and 10m long. It was then a light bulb went off in my head, so I bought it and headed home.
I then slid one end of the tube over the furthest rear caliper nipple and routed the hose up to the bake fluid res. Leaving a bit of slack, I then cut the excess tube off. The cut end was then inserted into the brake fluid and kept in position with a weight. I then undid the caliper nipple and began pumping the brakes.
It didn't take long for the brake fluid to begin pumping back into the res and at this point I stopped to top up the res to make up for the short fall of fluid in the tube - it wasn't much but just good practice. A few more pumps later and a 3 large air bubbles could be seen working their way out of the system. The bubbles simply pumped into the brake fluid res and burped themselves to atmosphere without introducing any more air bubbles to the system.
Once satisfied the caliper was sufficiently bled, I closed the nipple, removed the tube and then repeated this on the remaining calipers as per the directs shown in the FSM. I reckon I pumped the pedal about 20-30 times for each caliper and managed to get anything from only a few very small bubbles, up to larger bubbles. I also noted there was no consistency, as in the bubbles could be 1-3m apart but they kept on comming.
I now have the best brake pedal I've ever had and this bit of hose is now permanently part of my brake kit.
I recommend this to anyone who is having issues bleeding brakes and just can't get a good pedal for love nor money. Of course, it's a good idea to make sure your brake system is fully flushed with fresh, clean fluid before doing this method - the last thing you want is to be recirculating old fluid through the system.
I would rate this exercise as
Best of luck and happy stopping![]()
Saw Rick (LandTank) suggest a rear axle, LSPV, front axle, LSPV x 2 procedure, then found this, which can't believe it hasn't been a more commonly accepted procedure, if it works.
Endless bleeding.
it works much better with two people
