She does, but her pleas of mercy are commonplace, usually three quarters the way through a 1000k marathon.
there is some special service tool needed that connects in and makes the ABS pulse, thus forcing the air/fluid out when you are bleeding the brakes.
It's a wiring harness, that not even the local dealer has, that plugs into the ABS motor (pump, whatever) and engages, but I was under the impression it didn't pulse, but allowed for checking resistance only, to see if "bad".
Betting money that's the issue and betting money it was after an exit at Clayton where I became so vertical, that I lost all brakes....this after losing power steering.
Just ditch it and the LSPV and be done
Here's my question on the LSPV.
If it's raised at the arm, it effectively engages the rear brakes at 100%, right?
Even that does nothing to improve stopping, noted during an on lift test where the LSPV was opened and brakes applied ( no load ).
The front was completely stopped long before the rear showed signs of slowing and at an estimated. 3/4 brake pedal travel.
Has to be something else, too.
You don't need a " non US" MC, just one from a FJ80. Also no wires in the dash need cutting. The ABS bulb is removable.
That thought resulted from reading ten queries a week on an Australian FB page, where they're constantly asking what the ABS light on the dash indicates, which can mean same as here, being low brake fluid.
One went on to describe what ABS was on an 80 and why it sucked, so drew the conclusion that they don't have ABS, but reserve the function of "low fluid" lights.
You ought to go ahead and P/T the truck as well!
Meh, just need to find a way to get this through customs legally, then nestle on a US donor chassis and convert to LHD.
Not like I don't have enough friggin' projects, already.
