semlin
curmudgeon
I "think" the diesel switches are different in early trucks because there were two servo valves routing the diesel, IIRC. The later switches for petrol are all I had to test in the original install. Where are you guys getting the factory ECUs? Or are you not using them?
i think most are going to be repurposed to transfer tank switches since that appears to be the easier set up. for 100 series owners it will likely just toggle the dash gauge with a separate transfer switch rigged elsewhere.
i am still thinking about an oem setup but i have not yet tackled your thread. i've never understood why a different ecu is necessary.
