hi all...im wanting to upgrade my 1991 80 series roof liner with the later 96 board type....my question is what parts are needed exactly to do this modification..thanks...
All interior pieces from the bottom of the windows, up. Seat belt upper brackets are slightly different. Take the seatbelts as well. However, the buckles may not interchange from 96 to 91.i take it theres 6 pilliar pieces .to get ....im not sure if the seat belts need changing as well and is the roof panel held in place with clips ...
There is a thread on it here someplace.im thinking theres a little bit more to this mod than i am aware of. and overall the cost will be cheaper than a new rod liner......has anybody done this mod..?..i carnt find much info on it here in Australia
Someone swapped a 96 into a 94. The roof stuff is similar between 91-94, then 95-97.
Maybe search 94 headliner.
Yup!I fought the headliner and the headliner lost
So you have an old school headliner? And you would like to remove it because perhaps your sunroof leaks? Or you need to run a cable? Make sure your hands are clean they say. Its tedious but doable they say. NO WAY I SAY! Is glued, its screwed, you need to take our your damn windows cause its...forum.ih8mud.com
Is this the one you’re referring to?
