Did you know you can refinish your wheels for about $40-50ish!!
Items needed: Paint stripper (2 cans), 400 grit sand paper (for wet sanding recessed areas of wheel), abrasive pad (for wet sanding face of wheel), adhesion promoter (1 can) and dupli color clear coat (2 cans)....oh and some tape & newspaper to cover tires.
A pressure washer made things a lot easier....I let the stripper sit about 20 min then pressure washed (did this twice) then scrubbed till all areas were clean with the abrasive pad while flushing with water hose. I hit the recessed areas with the 400 grit wet sanding to create a contrast. You can polish to your liking, but I used the abrasive pad very lightly around wheel in a circular motion to make wheel surface look even. It has a slightly subdued aluminum finish...I like it. You could use an aluminum polish and buffer to shine it up more.
Next adhesion promoter, then 3 coats of clear....Done.
Oh! and the center caps I did using a solo cup (from Costco....I'll try to find which size it was). I painted the cap black then popped the solo cup lip into the recess on the center cap (fit perfectly) then sprayed the rest with aluminum colored spray paint then clear.
Guess it was 25mins.
