ARCHIVE 80 Series - Did you know?
Did you know...the 3FE's standard timing is 7 degrees while the 1FZE standard timing is only 3 degrees.
Just learned this tonight.
@NLXTACY there is also an 11 mm that is necessary for the heater control valve. Ask me how I know.
EDIT and note That's the nut on the spring actuator, when you shut the hood, mounted on the firewall with the heater control valve. 11mm yup.
Dammit, I was just going to check myself and call shenanigans :P
Did you know that when installing your lower control arm bushings there is a proper phasing for installing them?
Did you know that a couple zip ties can cure your side view mirror shake?
Did you know there are no diesel LandCruisers anywhere within a 100km radius of Tokyo.
Oh...maybe. I go to Nagano and Tokyo all the time but I could possibly be fined for doing so....hasn't happened yet.
Did you know that my OEM original gas cap on my 92 80 says TEQ? I just noticed this today when filling up. :)
I really just wanted to bump the DYK to the front page. Page 7 is no place for this thread!
Or just straighten it on a log after warming it up a bit.
Did you know warming will likely take the temper out of the tie rod.
Pin 7 mod : low range without lockers baby!!
Did you know the emblem on the hatch is a covered keyhole?
If you are having issues with EGR a common failure is the modulator. Originals had a green sticker on the top, your new one will have a blue sticker on the top. (Based on a '94)
