- Thread starter
- #21
For my 77 I bought new calipers, wheel cylinders, and master from Rock auto. New booster from @Racer65 . None of it was crazy expensive, so my advice is to redo it all and be confident that is done properly. Consider machining drums and discs. I was unable to source any rear drums, and luckily mine had enough metal to resurface.
A couple of things: Bench bleed the master, and read about bleeding/burping air out of the rear cylinders (the design tends to hold air in the cylinder). Bleed system, Adjust the rear shoes until wheel stops spinning then back off a little. Test drive, rear brakes shouldn't lock up first. If they do back them off some.
I did everything except the booster during my rebuild. After I couldn't get the brakes like I thought they should be, I bought the booster. That was the icing on the cake. Many thanks to @Racer65 for supplying a replacement. HTH.
Awesome. This is great. May have to run my shopping list by the group to make sure I am not forgetting anything. The wheel cylinder's were replaced 2 years ago so they are in decent shape.
