My truck isn't going through a build in the traditional sense (it's more of a de-Proffitt-izing / correction phase ) and I can assure you I exceeded $39K quite a while ago.
There is just no way that any business can offer a turnkey 79/80 for 39k , a private person with the right connections and time to wait for the right donor deals and free labor might be able to get close to that number but anyone at an hourly rate that needs to make a profit can’t even come close to that.
You get what you pay for.
Cheers
I'm inclined to agree. Small parts add up fast and *j79s have alot of small parts.Interesting
Maybe I'm crazy, but $39k seems low. I guess that "starting at $39K" is pretty vague in what you actually get. I suppose this is one way to get a 79 in the US.
On the other hand, $39K will buy a brand new Middle East spec *J79 and leave some change to ship it in pieces. I have considered parting out new HZJ76s/HZJ79s if I ever found myself with the spare time for it.
New Toyota Land Cruiser Pickup for sale in Dubai, UAE - Dubicars.com
New frames can be had in the US through normal supply channels for between $5-6k. 26 week wait period.
You can buy a brand new 79 series frame from Toyota? Do you get to spec the frame for a particular engine? 1HZ?
It can be but you will need to widen the front fender mounts, not a hard job. The front mounts all seem to sit about the same height above the frame when comparing a 75 series, 79 series narrow and 79 series wide. Early 79 series (narrow) were basically 75 series with coils suspension on the front. Different inner fender parts but outsides were the same. As the V8 was wider thus came the introduction of the 79 series wide or as most people think of the 79 series. The frame was widened in the front 3 inches to make room for the engine and the new facelift was to cover the engine. US Customs has been educating their officers, at least up in the NW, so any truck coming in now should expect to be hit with the chicken tax. Only way to avoid it would be to buy a junk 70 series here and import the newer parts to make it look new. Parts aren't subject to the chicken tax, but there are other fees involve.
Yes. They are all spec’ed for 1HZ engines since that’s the supply chain that Toyota supports for the mining industry.
I assume the frames come spec'd for the H150/151 trans as well?
My thoughts were the 75 ended in 98 (year of my truck) and the 79 started in 99 which was fixed windscreen, extended cab length, and extended bed. Still the narrow front. The modern front started with the V8 diesel but still stayed 79.I just realized, the J75 to J79 name-change marks the suspension transition (leafs to coils), not the facelift transition (narrow vs. wide). The design facelift did not occur until 2007.
Thank you for the clarification!
No. R151F.
