74’ fuel return question Holley Sniper TBI install
Campbell, Ca
Hey all,
Wondering if the return line from the original carb set up will work as the fuel return line on the Sniper TBI setup. Not clear how that return enters the tank (baffles or what have you inside the tank) and if I can use it for that or do i need to install an bung.
thanks for the help!
My Sniper set up uses the return connector on the OEM tank 77100-60043 (9/73 - 1/79). I did run a new 3/8" rubber fuel line from the engine towards the back, with a reducer to the 5/16" hose just before if goes up into the cab to the tank. Note, I'm using an inline fuel pump.
Thanks @GA Architect! Good to hear. Makes things a bit easier. I mounted the fuel pump and pre-filter back by the rear axle. Inline as well.
