- Thread starter
- #81
Front right wheel cylder leak check
Looks like both sides are dry!
because you will not believe how easy it really is. Sitting in your Cruiser with the hood up step on your brakes. Pay close attention to the fluid levels in the master cylinder as you do so. Now release the brakes. If you have air in your system, the resevoir level or levels will drop. release the peddle and the level or levels will rise again. If there is only a small amount of air in the system then the drop will be small but you will be able to see it. If the system is air free you will see brake fluid flowing back into the resevoirs when you release the peddle but no change in fluid level.
I like my tools! This guy is my second favorite, right behind my 3lb drilling hammer.Use of the Vacuum Brake Bleeder is straight forward. I put the box end wrench on first, place the hose end over the bleed valve, reach over and latch the bleeder handle down so it is drawing air then open the bleeder valve. These puppys gobble air though. You can run them at 175psi (12bar) for you metric people. They function by simply blowing air across an orifice, no working parts outside the switching. No need to turn off the brake bleeder during the process unless of course you have pity on your compressor. Leaving the Bleeder running after disconnecting the hose will pull any excess fluid out of the hose making the process very clean. A definite enviromental plus unless you consider the huge amounts of power your compressor is drawing to keep up. At higher pressures it will bleed your brake system in seconds. I run it at 100psi. Not wanting to pull the Master Cylinder through the hosesI like my tools! This guy is my second favorite, right behind my 3lb drilling hammer.
involved! All of them are marked with a 1/8. I must assume this is a reference to the bore diameter and means, 1 and 1/8 inch.
I think those say 7/8![]()
Good call! And thanks alot! Leave it right there. This is the second time in this "how to" that you have helped. Thanks!Thanks! I mean it!
