Build 60 Series Axle swap with the Trail Tailor Coil Conversion
Update to the last shock tuning post. Removed 3 clicks (2clicks from full clockwise) of rebound and added a click of HSC in the rear and it’s MONEY.
I was getting some harshness from being over damped on rebound and the compression was over compensating after big speed humps. It’s smoother now and softer and less bouncy even with less rebound dampening.
What I’ve been realizing is when in doubt. Add more compression. You need way more then you think and running open compression is NOT the move
Just a quick reminder to anyone doing this swap. Its easy to get in the weeds with everything going on, but dont forget the little bits that you need to do during the swap that dont seem super duper important....
Like greasing your front caliper pins.
Not sure to put this here or the LS Swap thread.
Anyone getting brake drag on both axles when hot? It’s getting toasty here in ABQ and after a bit sometimes I’m getting brake drag on both front and rear circuits
What MC and booster are you using? Is it your front brakes? I was getting brake drag but i didnt grease my slide pins like at all on the front. I got new pads, geased my pins and the issue seems to be gone
80 series stuff. I am not sure on the greased pins I can check.
It’s both front and rear circuits. Goes away after I park it for an hour
Weird. id check your front pads for wear and also the parking brake tension on the rears just to be sure. wonder if the MC or booster is slightly out of adjustment or something
Did you recently replace your booster? Push rod depth set correctly?
I did, and I thought I did with the tool. But that’s something on my list to check
Check and correct if needed the booster rod to MC depth. If the rod is adjusted into the MC too deep it will be constantly applying pressure, then when the brake fluid heats and expands more pressure will be applied. Since it happens at all 4 corners, and the booster push rod depth affects the whole system this is the first thing I would check.
Just wanted to post a 1.5 year update after doing this swap. Ive been daily driving the truck the whole time and just got back from a wheeling trip.
The swap wasnt that bad, even with the odds and ends at the end like getting my driveshaft angles and caster dialed, but overall its been 1.5 years and ive largely not changed anything.
The only change ive made is putting 100 series springs on the rear for the spring rate when adding a rear bumper.
This has been kind of a set it and forget mod for me. Its been really nice and still drives great. I drive it to and from work every day. Drive it up to the mountain and the beach here in Oregon. Take my truck up to 100 mph or slow drive. Can hit speed humps at 50mph and do little railroad track jumps. The only people who notice the swap are people that know 80 and 60 series pretty well, and it all looks factory so id say most people cant even tell its had the work done which is really nice.
Offroad its night and day. I dont lift front wheels off the ground anymore. Washboard gravel forest roads dont rattle my truck anymore and i can run higher speeds on them. Its more comfortable all around and the flex when wheeling is unmatched. Single black diamond trails that I kind of struggled to get through on leafs are like almost too easy now and required much less effort and much less body damage risk. Its not a buggy or a super flexy 3 link, but the improvement in offroad capability is very significant. I didnt even remove the front sway bar this past time and did all of the trails just fine, however when you remove the front sway bar, your flex dramatically increases in the front.
at 1.5 years im still extremely happy with this swap and happy I did it. I couldnt imagine running leafs again on 60. Also, im very happy i did the rear swap as well. I was on the fence about doing the rear at first and originally wanted to keep it leafs, because its A LOT more work to do, and more expense... but for me, the end result is worth it. Even with the rear sway bar on i get a TON of flex out of the rear and its very comfortable on the road. The only downside of the rear is with my corrected panhard bar angle, i cant run my exhaust out the back anymore so it dumps under the truck.
right now the only issues im fighting are:
- I used rock auto front sway bar ends (the oem ones are $120 each) and I can not keep them tight. When they loosen up they clunk. I need to just pony up the money for the oem ones.
- Every few months or so I have to go and tighten the lock nuts on the metal tech rear upper control arms for some reason. I should probably run some loctite on them but since theyre kinda hard to get to, Ive been weary of doing that.
Thats about it. I really want to figure out a way to re route my exhaust to run through the back, but with raising the panhard bar on the axle side, there isnt much space between it and the gas tank so for the time being its just turned down before the rear axle. No issues other than it being a little louder at WOT and highway downshifts.
I posted these photos on the photos thread but ill post them here too. This was this past weekend here in Oregon
What a sweet looking rig. It's kind of like when people put new frames under old muscle cars.
Funny, I was just thinking how much I love this swap today. For me, I have yet to establish the ideal shock configuration to pair with my Dobinson springs, but that's table stakes.
I also own an 80 series and there is just something about the boxey stoutness of the 62 combined with this swap that makes it absolutely perfect. I've finally got all my drivetrain challenges sorted (knocks on wood HARD) so I'm looking forward to stretching the adventure range this fall. But so far it's been a great daily and short to medium road tripper.
Totally agree. I will say, what ive found works offroad on the shocks, suck on the road and vice versa haha so i have 2 setups that i use if i remember to do it.
I like everything about the 60 better than the80 besides the suspension, and now that i essentially have the suspension its like the perfect cruiser. I just wish i had a sunroof haha
Love seeing tis pop up on Reddit. What shocks did you end up on? If I can unlock the right shock, I’m there. Factory Fox 2.0’s are just a little to harsh on small bumps like potholes, etc. I’m considering going with some adjustable remote resi’s like Icon or maybe Slee.
Im using the Dobinsons MRR adjustable shocks and i like them a lot. Theyre valved for the 80 series so youve got to run a little more high and low speed compression than youd think. In the video you can see how active the body is in the rocks. Thats from my low speed being opened up a few clicks before hitting the trail for more comfort on the trail haha
Copy. That’s very helpful…going to take advantage of Black Friday and you just helped me make up my mind. I might drive her out your way once I solve a windshield leak. I’ll definitely buy you a slice for all of your help with this setup!
I’m retaining the leafs in the rear but super excited about the coils up front. Hopefully in a month or so I’ll be able to report back.
