I have almost the same problem. Flipped front springs. Lower profile shackle reversal. Cut and turned from axle (forget, but lets say around 14 - 18 deg). I had to send the passenger arm back to luck to be bent more when I was running stock knuckles - he bent the new ones for the 6 shooters almost the same. Without bumpstops, I am hitting both the frame on compression - and the spring on droop. It's not bad and there's not been any carnage on that end. I have one of Mudrak's flat homebuilt pitman arms - pure beef - but it touches the drivers side spring on right turns when the driver's side is compressed.
Has been a royal pain in the arse - everything is just a hair away from being perfect.
Before all this I had a bad AGR box that didn't like to turn left. Had PSC rebuild it and am attributing these steering issues or severe sideways driving with screwing up the steering again.
Going to get the box/pump rebuilt - go with bumpstops to limit excessive uptravel - and maybe work the turning bump stops out a hair....
Understand your frustration.
