- Joined
- May 3, 2013
- Threads
- 61
- Messages
- 506
- Location
- Upstate South Carolina
- Website
- www.nexgencontractors.com
- Thread starter
- #121
Yes I didDid you end up using stock 1FZ buckets and shims?
Yes I did
Cometic showed up today so I made good progress with assembly. Looks like I might be dropping it back in the truck this weekend depending on weather.
@scottryana knowing that I am going with the bolt on turbo kit in the NEAR future I hope lol...I was thinking 3" exhaust bent over the frame and a Flowmaster 60 series muffler or similar to keep it somewhat quiet. With the target HP I was thinking this should be free flowing enough but wasn't sure if it would cause an issue with the turbo spooling too quick like you mentioned in the bolt on thread.
Yeah that's what I was thinking but wanted to be sure. ThxIf you are going with a stand alone computer you can spool the turbo as fast as you want!
It's beautifulSo the block and head came back from the machine shop. Had a good time assembling the pistons and rods though the JE piston pin clips were a pain until I figured out a technique using a pick to work them in. I decided to use a catalytic single stage paint for the block, head and valve cover. Standard black and Toyota Barcelona Red for the valve cover to give it the TRD look.
Waiting for my Cometic head gasket to show up tomorrow. I went with .066 thick.
Also cleaned up the intake, bottom cover and other aluminum parts using Alumibrite and was impressed how well it brightened up. Hopefully will have the motor back in the truck next week.
Yep, getting ready to bolt up transmission and drop it in the truck todayIt's beautiful
Yes I have just haven't taken the time to post up. The engine is back in and running great. Did the break in and just switched it over to Amsoil.Did you have a chance to get any farther on your truck? Engine looks great.
Also, did you wind up with the Haltech elite 750? I think that is my pick for management (when I finally get this rolling) except it does not support knock sensors/control. I have read differing opinions on the need anyway but still not sure. I kind of feel that if the tune is right it should be a non issue.
Yeah I was thinking I may leave the cat for now as I would like to see Dyno results and then remove it and see the difference in power that is why I have it flanged on both sides for easy removal. I looked through the other cat that is removed and it seems to have a fair amount of screen obstructing the airflow so I am curious.Keep your cat. My wife makes me hang back a 1/4 mile or change lanes whenever I'm behind a stinky vehicle. One high-flow cat isn't going to rob you of much power.
Yes agreed I need to do a couple finishing touches like those. Willing to buy if your still selling them!Good work. You are missing:
11291-66010
12180-13010
Otherwise, tits all the way!
Thanks man, hearing and seeing your LX is what started me down this road of madness!Truck sounds great when you fired it up! Great job
Also forgot to mention I installed the part time kit from cruiser outfitters as well as rebuilt the T case with all new OEM parts which made a world of difference. No more driveline vibrations!
