Yeah the Carillo SA's are awesome! Great choice!
Not sure I will have to measure them and get back to you.Are the aftermarket piston wrist pins the same size as stock? 2.750"x1.024" What wall thickness are they? Do they advertise the material? Thanks!
Yeah I will have to get a side profile shot and compare to yours to see how much they did. Now I am curiousOh wow they back cut your valves a lot more then they did mine!!
Greenville South CarolinaWhere is this project at?
400hp and part time will be fun. SmokeyFigured I would give an update. I am currently still waiting for the block and head to get back from the machine shop and hopefully I will see them both in the next week or so.
While I am waiting I went ahead and did the Transgo shift kit which was pretty straight forward after reading a couple threads on the install. I also pulled the transfer case apart and did the part time kit from cruiser outfitters. I still need to either have the birfs I have machined or buy a set with the groove already machined. While apart I went ahead and replaced all the bearings, races and seals. 300k miles and the originals were surprisingly like new still....beefy setup. I did have to fab a tool to get the two inner races out which consisted of a slide hammer with a lady slipper type hook welded to the end. Other than that pretty simple with a press and some various sized pieces of pipe and sockets for pressing the different size bearings.
That's the idea.....donuts on 35's!400hp and part time will be fun. Smokey
I am not 100% sure because I have been only researching based on my build which here in South Carolina we dont have emissions checks. I am pretty sure you can piggy back the factory ECM so that both the factory ECM as well as the new ECM can share the O2 signal inputs. The only difference is that the factory ECM will think it is controlling the ignition system based on those signal but in reality the piggyback ECM will be. The reason this wont work on my application is because I am installing a new exhaust and eliminating the cats and the post cat O2 sensor and installing only a single wideband O2. You may have to install a wideband O2 sensor as well as keep your original 2 factory narrowband sensors for programming purposes. Like I said before though I haven't researched that route so I may be way off.So, I'm really fuzzy on the engine management side of this, but was there no way to piggy-back the stock ECM? Since I need to maintain the emissions stuff I'm curious if it's possible to maintain OBDII legitimacy somehow.
I haven't read about the spacer I will have to look into that. It does make more sense than going through the trouble of machining.Why not use spacers? I've seen others mention machining the Birfield, but my Lokka part time kit came with spacers for '95 - '97 rigs.
It'd be pretty easy to make one if you had the right ID tubing. Or a lathe, then it wouldn't matter what you started with. Plus, the bonus to using a spacer is that you don't have to disassemble the front end to remove the birfs.I haven't read about the spacer I will have to look into that. It does make more sense than going through the trouble of machining.
