I’ve got them but they aren’t perfect. You are welcome to them but there is no way I’ll have time to pull them off before we leave for Rubithon in four days. You can pull them while I’m gone or wait till I get back if you can’t find any others.
View attachment 1732520 View attachment 1732521 View attachment 1732522 View attachment 1732523 Being reassembled as we speak.
@Bodean what shocks you got on the purty truck? The huge yellow skyjacker sticker on the tuffy has given me a good idea of what springs it has, but I have tracked a clanking up front to the passenger side shock and its non-existent bushings. So gonna just replace all 4 corners. '78 sprung under with what I believe are 4" skyjacker springs.
Appreciate any suggestions. Thanks
This has worked really well on mine:
https://www.permatex.com/products/g...ermatex-the-right-stuff-1-minute-gasket-grey/
A good bead all the way around the housing with a complete circle around each bolt hole. Put the cover on and run the bolts down immediately. Fill it up the next morning.
Bodeans shocks are probably 20 years old.
If I was you I would take them off. Go flex out your truck by driving 45* into a ditch. This will make your tires on opposite corners hang in the air while the truck is level
Measure your stuffed sides and your stretched out sides.
Go to Bilstein website. Get some 5100 series shocks.
