4 door Fj45 on 80 series chassis (3 Viewers)
I even see the magic dial .It has locked axles.
I don’t recall if you had those already, but it would be super easy to swap in the complete axles.
It's good to hear from you again. I'm glad you're ok. I was going to suggest that you pull some strings with your son the Marine and his guys to get the 80 for you but, looks like you handled it. 👍 👍
The local gang chief ended up getting a whole 30 bucks out of the 100 to let it pass thru his territory to the next. I gave him his 30 bucks and the truck made it safely to the shop. I saved way more than 30 bucks not having to buy my missing parts. I have an extra engine for my 40 which sports a 1hz too.
I'd have given him 10 times that if he asked but $30.00 worked better for me🤣🤣🤣🤣🤣
A set of locked axle is going for $ 2500.00 + US, state side. DBL score. Even more with complete wiring harnesses.
And yes you should
And yes you should
Say no more😃
Here is the motor
FWIW locked diffs won’t fit in none locked housing without significant modifications.
Locked diffs have special axles shafts that will work in none locked diffs & housing. but none locked axle shafts well not work with locked diffs.
Hope this helps.
Hope this helps.
Oh ,yes it does !😜
You can be certain that both units are going under that 45 . Thanks for the info !
Amazingly enough, we found no fluids in the engine. I poured oil in it, slapped a pair of batteries into place , poured some diesel in the tank.... turned the key 🔑..... Started right up. AMAZING !!!!
We put it in drive and took for a spin around the yard. I almost feel bad about parting it out but I will feel worse buying all those parts. I will eventually install the 1HDT on my fj 40.
Things are good. Hope they remain that way😁
Awesome, so glad to hear things working out! Great score and sounds like you’re gonna make great use of the rig!
I had decided to have two tanks on this truck. I already had a plastic unit froma land rover and the other was from a 93 corvette.
The corvette's tank was gonna go under the cab and while I can't complain about space availability , I wasn't sure i liked it either. So , I decided to to only have one, but one that would easily hold as much as two...... a monster of a tank that will not stick down from under the truck and will not rust.
Full stainless steel construction..... baffled to prevent the fuel from flushing around and stong . Meet my new fuel tank🤩
Ok. Tank is almost completed. I made holes for the drain plug and for the sending unit and vent. I installed a 3/8 threaded outlet port . Hope it' enough to feed the 6 liter It came out a bit heavier than expected . I like it. This thing will probably not rust any day soon.
We'll pressure test it for leaks and make some stronger support straps.
45 gallons.
I grossly miscalculated this tanks capacity..... today we filled it up to the top with water then emptied it out 5 gallon bucket 🪣 at a time. It took a total of 12 buckets + 2 gallons to empty it out. 62 gallons is the exact number.
Holly cow ! That's a whole lot of fuel 😮
Well i 'd hate to be waiting to fill up behind this monster at a fuel station ⛽️.
After measuring the tanks capacity, we mocked it up into the chassis. perfect Fit 👌
Hangs down maybe 2 inches lower than expected , but I still have a bit of room to push it up under the bed some more. Here are some pics.
