4.30 or 4.88 re-gear
The combination of the 305's, and semi-heavy build (ARB front bumper, winch, roof rack, sliders, skids, 12.5g LRA, and planning for a dual swing rear)....plus I spend at least half my time in Tahoe. Driving up there with 250lbs of dog in the back (Newfie and a BIG Golden) and my experience leaving my old 2017 4Runner stock with a similar build was enough to regear the 200 from day 1. I'm hoping the 4.3's are enough - made the decision based on erroneous tranny gear ratios provided by the shop I'm working with...can't wait to get the truck so I can finish "dialing it in."
My rig is 2013 6 speed . Is your rig 2016+? That would be a 8 speed trans.
I hit the East side of the Sierra but no farther than Bridgeport. But I could always make a day road trip when I’m in Mammoth.Is your build heavy ?
What made you go 4.3?
Thanks brah!
Want in on any eastern sierra action. In Ridgecrest. Looking forward to getting the Kamparoo out with the LC200. Have always towed it with my 4Runner since the LC was the wife's DD. It's my DD now. 😈
On the thread subject, my 4Runner is a 4th gen with 35s and 4.88s. It's a lot of gear for that rig with so few tranny gears, but it'll chirp the front tires if you want it to. Drives better than stock, imo.
Sounds like you have your solution.
I can check actual numbers this weekend, but everything about our trucks gearing is different - tranny gear ratios and I believe diff's
Not 100% sold on the 4.3's being enough for the 16+ yet, but we'll see.
Rpm is going to vary with tire size. With 35s and 4.88 it is 1750 at 65mph
Really?! On 2016+ I thought that would be plenty. Keep us updated. What makes you “ not sold” on the 4.30?
Not enough driving time yet. REALLY bad final delivery experience that has kinda made it hard to enjoy, and she's been sitting in the garage.
@SQRRRL I got to drive Rob's truck with 4.88s yesterday. Without a doubt and zero hesitation, you want 4.88s if you are spending the money to re-gear. Rob's truck probably weighs about 400 pounds more than my build that sounds similar to yours in terms of weight. I really loved the difference in engine braking in 2nd and 3rd gears going down hills. Also if you are to believe the computer MPG readout, his heavier truck gets slightly better fuel economy than mine, which could potentially be attributed to the gear change and keeping the motor in a more fuel efficient RPM range for a given speed with less down shifting.
P
Great feed back. Thanks.
Engine braking has been an issue. Now I need to decide if I want to go with 34’s on RW’s. Mostly for looks but I think perhaps next year.
Sorry to hear that brah. It will work out. These builds are not easy.
They got the hard part right (gears/lockers) - it's one of the items I could have easily done myself, that they screwed up and left a permanent reminder.
Giving it another day or 2 before deciding if I can live with it or it will be something that drives me nuts every time I get into the truck.
Live and learn...never again.
I feel your pain. Good luck brah.
I know what a sour taste this type of occurrence can leave, been there, hate it for you.
@nor_cal_cyclist, you should read the post on the Pedal Commander PC27 for the LC200 16+
Sounds like it transforms the performance of the 8-speed tranny and might just be what you really need.
I'm looking at a regear as well in my 2013 LX570. I'm running 33" tires on it (no other mods) and there is a very noticeable penalty to acceleration, braking, and mpg. As @CJ3Flyer mentioned, it's most pain in the ass when fully loaded trying to maintain 75+mph, especially with any kind of incline--constant shifting, won't hold cruise control, rarely get out of 5th.
A 4.3 in the 08-15 LC200 restores the shift points to just better than stock. So, looking for arguments as to why go all the way to 4.88? The advantages at low gears--acceleration, crawling, towing, etc--are clear to me. What's not clear is how it will affect high speed/high gear performance. I regularly drive on the freeway in states with an 80 mph speed limit (which of course means I want to go 90 :p). The (calculated) difference between stock gearing/tires and 4.88 gearing/33" tires at 80mph is 400 rpm (~2000 rpm stock vs ~2400 mod).
Incidentally, I ran the numbers, and a 4.3:1 diff in a 16+ cruiser is equivalent to a 6.2:1 diff in the 6-speed models... Whoa! That's crazy low dude!
Just spoke with Carl of Nitro Gear/ Just differentials ,he says 4.88 for the gen 1&2 LC with the 6 peed trans. And I have 285/65/18’s. Pretty much what the guys on this forum have been saying all along.
another reason for 4.88 over 4.30, I was driving up a 6% grade fully loaded in the rain. The rain nearly stopped me dead in my tracks. Never experienced this kind of physics.
Without getting into a bunch of physics, my experience in re-gearing off-road focused vehicles is you need to go beyond simply correcting for tire size (if we’re talking drag racing there’s a lot more that comes into play: tire diameter, torque converter stall and “tightness”, engine power band, etc). What you’re really correcting for is the additional unsprung mass that comes with upsized tires. And you’re also likely worsening the aerodynamics of the vehicle (through additional vehicle height) and increasing rolling resistance. In short, this is one instance where intentionally overcompensating your modification makes sense. The RPM difference you cite is 1) not a noticeable difference inside the cabin in terms of NVH 2) actually puts the engine closer to peak torque. I’m not aware of any instance on this 200 subforum where anyone has ever felt they over geared their rig. I think even though we say 4.3s is preferred on the 8spd, the folks who have 4.88s with that combo have zero complaints.
