Registry 3FE Owners Check-In (4 Viewers)
Is it worth the money, time, and energy to install 4.88 gears on a 1991 with a 3FE sitting on 33's? Or is it a none factor?
I personally would not bother regearing for 33's. That's just me, if you were running 35's or larger I'd regear. I've got 5.29 on 37's and I like em, but mostly for rock crawling and using my gears going downhill instead of braking. The better time/money would be spent regearing your transfer case, it's much easier with less skill/specialty tools needed.
What would your recommendation be for regearing the transfer case? Thanks
As far as I know there is only one gearset for transfer cases, oem low range is 2.49:1 and the reduction gearset takes it to 3.11:1 which is a 25% reduction. I've read on the forums that this is about the same a 4.56 gears in the diffs. The hf2a is a simple thing, gear driven and relatively easy to work on. I didn't do the high range gear, but I should have.
I did the Sumo low range and part time at the same time on top of the 4.88 gearing in my 3rd. This combo is perhaps the best upgrade for regearing close to 5.29 with the strength of the 4.88 gear.
Hello! A bit of a diagnosing inquiry. I have a 92 3FE cruiser and lately the coolant temp sensor has been acting funky. Gone on two 6+ hour trips in the past week and the temp sensor will usually sit all the way at the bottom as if the car was still off, occasionally though it will jump to a random spot, sometimes at the correct temp, sometimes higher, and usually lower, it’ll jump around and after a couple of minutes it drops back to off. Things I have considered are… 1. Bad temperature sender 2. Bad wiring somewhere, possibly from the sender 3. Thermostat stuck open or 4. Something else lol. Recommendations?
it is the wiring for the sender i bet. I had the same problem where the temp will read lower than normal. rewire the sensor to see if it works.
Hi,
What do you guys think is going on here?
Brake is not on, vehicle just started… wiring?flashing on and off as I drive. Very intermittent.
Where should I start looking for a loose connection if it is electrical?
These are 3 of the 4 lights that come on when I turn the key to acc but havent started it yet, the last one being check engine light which on mine was burned out. Before I replaced it it looked like this. Maybe the truck doesnt know its on yet for some reason
I just became the owner of a 92 LC. Currently in he process of removing the radiator, repacing the head gasket and wil be doing a de-smog. 156k miles. The previous owner let the LC slide on maintainence for a while. I'll be catching that up over the next several months. Then plan on a 2 to 3 in lift. and I want to install a part time kit with locking hubs also.
Welcome. That is a fine looking 92
My 92 with a 3.5" lift and part time kit.
My (now sold) 92- miss it, sniff, sniff
After chuch, I decided to drain the coolant, remove the thermostat and do a flush or two on the cooling system.
You know what they say about a 30 minute job? All is well until you break off a bolt. Also I found a mess. Spent all afternoon cleaning a flushing. I started with a CLR, ran the engine for 15 minutes. Drained, flushed. Then 3 more flush cycles using mixture of TIDE / Borax. I added a 50/50 mix of green anti freeze.
The broken bolt. I attempted to weld a nut on the "nub" 4 times, no go. Had to go to NAPA to get a Tap. Drilled it out, picked out the pieces of the bolt, then re-tapped the hole. Turned out good. Had to use a hardware store bolt for now. I'll order 4 new bolts for long term. It's all got to come out anyway when the head comes off.
I have a radiator, head gasket, water pump, belt idlers/tensioners, de-smog kit and gaskets on the way. Most likely I'l need a bunch of hoses too. I'll drain the coolant and flush again when the project starts.
