Registry 3FE Owners Check-In (14 Viewers)
I installed and really like the RLB Pro8. Less expensive than the alternatives. Small. Easy install. All serviceable on the trail with fuses and relays. I have my fogs, ditch, bumper, rear lights as well as my air compressor, cb, and shortwave on it. Solid kit. Good price. An actual person answer the phone AND ANSWER YOUR QUESTIONS when you do something stupid and need a direction to fix the issue...:bang:
Do you have any photos of install/mount locations? Thanks for the info!
Ooooo!!! Pretty snow flakes!
Merry Christmas!
Sorry for the late pictures. Completely forgot. Here you go. Don't judge me on the terrible wiring. I swear I'm going to clean it up... Someday.
Happy New Year 3FE gang. Just completed a 1000 plus miles trip down in Baja, Mexico and back without hiccups. The new 90 amp alternator works like a charm from @ToyotaMatt. Thank you again, a few pic for your enjoyment.
thank you for the solid technical feedback marco , glad you had a safe trip and phun one too i see above ... :)
only one thing ?
you forgot to post a few installed TECH. photos of your NipponDenso new-born , is it a boy or a girl :idea:
happy new year ...
matt
LINKS NOW ACTIVE above and below
something new and wicked , from a fresh perspective pipe dream i had over the holidays , for the 3FE 80 Series community , in-fact all 80 series 1991-1997 ...
- a all OEM Parts Harness Side Fusible Links Connector repair and restore / refresh kit
- hand-assembled in-house at the Skunk-Works Laboratory , using Japan-Spec parts and ANCHOR marine grade heavy duty tough as nails 10ga wire , correct white w/ red tracer stripe configuration as well ,
- also , includes a 3-M low temp. crimp & heat shrink butt connector , these are the best of the best on planet earth and made here in the USA , one of the few usa parts i will ever incorporate into anything i have going on ....
- 90982- is here to stay ....:)
i have decided to tackle a some what complex NLA / Disc. 3FE FJ80 parts need topic that can eventually evolve naturally
into FZJ80 on it's own as it will ....
i was approached over the holidays by 2 fellow members at different times , whose inquires were not related ...
- Part # 85340-60040 MOTOR ASSY, REAR WASHER
- - if anyone has better TECH. photos of the particular GREY device side connector or the matching mating harness side one too , please post it here in 3FE check in thread , i found ONLY this one image after several hours or R&D on this broad brush entire engine bay front windshield and rear window washer bottle , both pumps , and anything in-between ....
- i have all the puzzle pieces sorted out and a 6pack of the needed parts and supplies to create a all inclusive all OEM japan spec. parts plug and play solution problem solver master kit form kit ...
- except this darn rear washer pump 85340-60040 and both the assoated plug connectors ...
- i have a HORDE of NOS Genuine NipponDenso general service parts waterproof cold spec. pigtail equipped leeds washer pumps on-hand , that base is covered ,....
- so it's really down to sourcing both connector plugs ?
- i pondered simply using a different style water proof connectors set up i have on hand , but the alienates and forces someone to chop off and replace the harness side existing connector plug , and i simply won't have that monkey business going on . that is the PO way ,
not mine ........ :D
- here is tech. images :
only one thing ?
happy new year ...
matt
Here is a pic of the 90amp alternator installed. =)
That’s exactly what I need, thank you, I looked under the 80 series tab on your website and couldnt find it, I should have know to look under the 62 Tab
i should have FJ80 in the description ?
i found this the other day late at night randomly KEY punching as i some times do , looking for interesting things anything TOYOTA Land Cruiser ..
it's phunny because i happened across these 2 images while hunting for NON-USA 3FE anything variation topics on that unique NLA / disc. rear washer pump above im trying to make alive once again ..
this is the type of smack that inspires me to do what i try to do ,
note : other then simply tagging these with my little blue SNOW VERSION professional mission statement PEN name logo sticker , these are not edited in any way ....fyi
i did my home work and R&D too and this absolutely was a real modle early era 80 series in JAPAN Spec. market , the 2nd image is of a real legit original sales brochure , the top image is a artistes' rendering of course , but study the details in both images closely , there both pretty dam kool
Question, @ToyotaMatt (or anyone else). How is that spare riding on the tailgate without a swing? Very interested in this kind of lash up... I don't need the ski setup (Mexico) but want the spare off my roof.
The non US model sometimes come with a factory tire carrier/swing out that is attached to the rear quarter panel. So the spare is not riding on the tailgate but the swing out itself.
i only know as much as my chatty matty introduction above ?
the rest is still unlocked 80 series TEq knowledge to be had ...
I've seen that. The pictures from the original marketing material doesn't show the arms of the swing out. I was curious if there was some Toyota magic afoot. Thanks for the reply.
1 looked up a japan market VX Turbo MTM 1991 HDJ81V-RNMEX and this might help answer your question ?
