New OEM fusible links are $12. Why give this a second thought?
Try unplugging the AFM connection. If the 2 phillips screws on the AFM housing were removed and the internal circuit board was moved, then there is likely a fractured wire. This can prevent the ECU from entering the "ready" state and energizing the EFI relay.
I would make sure that each pin of the EFI relay socket is good. Here is a diagram of the pinout along with the OEM wire colors. Make sure you're getting a good ground on pin 1 (brn). The pin 2 (red/yel)+12 comes from the EFI fuse and should always be present. Pin 3 (red) is the logic signal from the ECU that energizes the relay coil and it should read around +12 or so with the key in the ON position.
You will not get +12 at the diagnostic port until the EFI relay is closed.
@jonheld do you have similar diagram for the relays in the driver's side kick panel?
I am having trouble getting my rig to start. My situation is different, that OP. All of what I am saying is before I found your diagnostic procedure this afternoon at work, which I will go over when I get home.
My family and I were running some easy trails near our house, when we stopped to look at a moose and the engine shut off. I let it sit for a minute before I tried to restart it (I had had no problems like this before), so after I let it sit while my kids watched the moose I turned the key and it fired right up. About 20 min down the trail (we were 1.5 hours into the trail) we ran into a 25' section of 8" deep mud that we drove through (mud everywhere, but not stuck) and went on our way home with no issues.
When I got home I parked the 91' in the driveway to spray it down and get the mud off the body, knuckles and undercarriage. When I went to start it 30 min later it would turn over, but not start, it was late so I pushed it into the garage and figured I would deal with it the next day.
The next day I went out to look at it, figuring that somehow water must have gotten into the distributor cap and was stealing spark, but it was dry inside. It did have all what appeared to be the original rotor, wires and plugs, so I figured I would just replace those. So I put in a new rotor, cap, plugs and wires. Still it would not start, so I sprayed starter fluid in the air box and it acted like it wanted to start, so I knew that I had spark.
My next thought was that I am not getting fuel to the motor. I had replaced the fuel filter last summer, so I figured that was good so I went ahead and replaced my fuel pump, figuring it was likely original and ready for a change out anyway. I changed out the Fuel pump and Main EFI relay under the hood. So after I had it all put back together I tried to start it and it would still not start.
So today at work during some down time I hopped on IH8Mud and did some searching and found this thread and a few others and saw your diagnostic procedure talking about no CEL so I had my wife go and turn the key to on and the CEL is not illuminated.
Here is what I have done since this started:
1) New rotator
2) New distributor cap
3) New spark plug wires
4) New spark plugs
I know I now have spark
5) New fuel pump
6) Last year I replaced the fusible link and main battery ground.
7) I verified that I have +12v at the fuse/relay box in engine compartment.
8) New EFI main relay (engine compartment box).
When I get home tonight I will check the following:
1) B+
2) AFM connector
3) ???
Thanks in advance for any advice.
Will
