- Joined
- Oct 22, 2013
- Threads
- 16
- Messages
- 258
I have a $20 craftsman meter at home and I keep a free (with coupon) Harbor Freight unit in each car. Saved my bacon when I had to run this troubleshooting sequence on an interstate overpass in Chattanooga.
The sheet looks intimidating, but pick up a meter and start at the top with 1-4. That was what I did.
1.) I did have 12 Volts at the brass screw in the engine bay fuse box, which meant power was getting that far.
2.) If no 12V at fuse box... well, I had it, so I skipped #2
3.) If 12V at fuse box and no CEL... suspect EFI relay/fuse/wiring
I'd also read what others mentioned... there are relays identical to the EFI relay behind the kick panel just forward of the driver's door.
I pulled a correct-looking relay from down there, swapped it into the engine bay fuse panel.
Got in the truck, turned key, saw the CEL light up, and she started right up. I drove to a parts place, overpaid for a new EFI relay, then drove 2hrs home. Now I keep a spare relay and other electrical bits in the glove box.
And I never got to #4 on the died/won't start troubleshoot procedure.
It might not turn out so easy in your case, but from experience, this portion of it is totally n00b-accesible. So's the rest if you need to go further, you just need to take it a step at a time.
