In my never ending quest for parts for 3FE-H55 swap I have come across a dilemma. I took one of the bolts out of the flex plate on the donor 3F-E to use as a guide to acquire a flywheel, clutch etc. I find a bunch of 2F flywheels and when I try to run the bolt from the 3F-E though it, no go. The hole's in the flywheel are smaller than the bolt I'm using from the 3F-E, do I need to drill the holes in the flywheel out? Is the bolt hole pattern the same on the 3F-E crank? As an aside, the 2H clutch is the same as a 2F. Help!
