3Fe diagnosed, camshaft messed up?
Washougal Washington
Hello landcruiser family, I am a 19 year old from Washougal Washington, right next to Portland Oregon. New to ih8mud as someone suggested I post my problem here and I would love some input on my baby 1991 Toyota Land Cruiser with the 3fe engine. Long story short, I took it to the sand dunes, and while I was driving, the car gave out on me. It sounded like it misfired a few times and just gave out. The truck will now crank, but won’t start. I stayed a few extra nights at the dunes and checked fuel lines, replaced the fuel pump, checked the maf sensor, checked relays, checked the fuse link, and after 2 days of almost ripping my hair out I decided to just tow it back home. I had a mechanic take a look at it and he tested it, the codes came up as airflow meter and manifold pressure sensor. But he said these codes won’t stop a car from starting so those can’t be the problem. He basically told me the cam shaft is cooked. He didn’t tell me much other than that. Now I’m in a pickle and I have no idea what next steps to make. I bought the truck because I heard the engine is bullet proof… and 2 weeks into owning it it gave out on me. It was driving perfectly fine like a charm and then just broke down. It’s at 199500 miles, original engine and everything. If anyone can provide any help at all or just give me advice I would greatly greatly appreciate it. I’m not at all in the financial place to completely rebuild the engine, and I have zero experience with engines so replacing the camshaft would be a fun project, but how can I even know that’s for sure the problem before I go taking apart my 3fe? I appreciate yall in advance.
Welcome. You will get much more informative answers here than reddit.
I don't know what contributes to crank no start on a 3fe. I wouldn't throw any more parts at it. Check electrical. Could be a relay or fuse. Repla e any questionable fuses instantly.
Hopefully you didn’t pay for that diagnosis!
Start here and follow the steps from @jonheld he is the guru on 3fe. Download the diagnostic from the resources section and start reading.
Learn to fix this thing yourself. You can do it this forum is here to help. Ask questions after you have tried it once or twice. https://forum.ih8mud.com/resources/3fe-efi-diagnostics.89/reviews
Got spark? Did the ignitor lead come off? Bad afm will just crank when I had that, engine would not really catch
Basic questions/checks:
1) is the check engine light illuminated with the ignition in the 'on' position?
2) easy way to see if the cam is doing remotely what it should: remove the rocker cover and turn the engine over. If all the valves open and close in what looks like a logical sequence given the firing order, it's probably good enough for it to run.
3) Pull the oil filter and cut it open, if it's full of shavings something has gone south internally.
4) Do you have a factory service manual? If not you can download one for free in the 'resources' section of this website. This will have some troubleshooting sequences to go through
Please find another "mechanic" or reach out to a local LC group in your area for recommendations.
There is no OBD1 code for "manifold pressure sensor", considering there is no manifold pressure sensor on a 3FE.
What @Godwin posted is true, and it has happened. However it is extremely rare.
The distributor rotor is driven from the cam shaft. Pop the cap off the dissy and crank the starter. If the rotor spins, things look promising.
Please read through this document.
pull the cap and have someone crank it over make sure the rotors spinning 360 with no hiccups during that test. I’ve seen ford L6 motors shear the gear off of the distributor shaft they have a roll pin and you could gently by hand spin the rotor ( some times it would catch , get tight but then you’re off time and no combustion ) had to put a new roll pin in and your off to the races.. or gas station.
If there is a plastic gear in there it’s possible it’s cracked and spinning on the shaft, likely out of timing at that point. Good luck, keep us posted with findings.
The 3FE camshaft gear is a fiber composite and being 30+ years old may have deteriorated to the point it's no longer solidly connected to the camshaft.
Hey Godwin, when you have a second can you checkout this video and give me a second opinion on if you think that might be the case on my camshaft? Thank you
If that slot in the distributor hole is for the oil pump then the cam is not driving the oil pump. Pull the front timing cover and check your cam gear.
Easier check is to pull the valve cover and see if the rocker arms are moving while rotating the crank.
On the 3FE, the cam drives the distributor. The distributor drives the oil pump.
The end of the distributor shaft has a flat blade tip which fits into the oil pump.
If the rotor spins, the oil pump is pumping.
How can I pull my front timing cover? Thank you for your help
Look at any of @jonheld posts, scroll down to the sig line where he says buy your FSM here: click the link, download a Factory Service Manual and start reading.
