Another printed thing Hood risers
View attachment 2411157View attachment 2411158
They help keep under hood temps down, like hood vents without the need of a jig saw.I have to ask, what purpose do these hood risers serve?
Nice execution. I ran risers in my old vw days (karmann ghia's) in the summer. Common in that scene.They help keep under hood temps down, like hood vents without the need of a jig saw.
I like your train of thought! I am looking at radio shack and other various electronic supply web sites. I just need to wrap my mind around soldering cables into the existing system because the existing switch And electrical set up is a very beautiful and simpllistic system. The switch actuator was nothing more than this plastic piece on a spring that separated the two metal contacts when compressed! So yes If I can wrap my mind around how to implement a new momentary push button switch for $3.50 then I will definitely be doing that.
I can also just ditch the old System and install an LED light to switch and install new Connectors to plug and play with the existing wiring harness.
You could also use something like any of these which are easy to fit and some come already with wires so you just have to quickly solder and then cover with heat shrink. You could also combine an LED light with these.
Unidentified MFG - 3-410 - Switch, Leaf Blade Contacts, End of Stroke Normally Closed Pin Ball Contacts
Unidentified MFG - 3-410 Leaf Blade Switch Contacts. Contacts: Normally Closed (NC). Mech: 2 Mounting holes are 0.24www.electronicsurplus.com
Magnetic Contact Switch – Door Sensor – HandsOn Tech
handsontec.com
Can I make a request? If anyone has interest in printing something like this.
My antenna is vestigial. Might be good to have options on using the hole...
I know it's not an ideal place for comms antenna but for my needs, would be fine. perfect for a shark fin antenna/booster.
Do you have the time/ability to measure how much of an an effect these have on temperatures on the 80 or if you think these may serve the purpose better at a lower or higher traveling speed? I'm always on the look out for something to draw the hot air out of the bay going up steep grades.
Thanks for sharing with us your printed ideas!
@FirstToy i would gladly do it, just need easy access to the antenna hole. I'll take a peek today. I might have the old antenna parts. Whats the first thing you want to mount?
