Some said it could not be done. Others were unsure. I decided to try it out.
Due to a scheduling conflict, the wheels and tires I had been using needed to go to a friend's project. I knew I needed cheap wheels and tires in a hurry. I had some used 35" 12.50R15 BFG A/Ts... and Summit had $39 Black Soft 8's. I ordered the 15x8 wheels with 4" backspacing... got them the next day... mounted and balanced them (can you say lead beauty-ring?)... and then MOUNTED them - on the FJ40. I knew it would be close, I thought it might not work... but as it turns out, on my 1975 FJ40 with drum brakes and stock suspension, 35" tires on 4" backspace 15x8 wheels will fit and roll. I had about 1/4" between the lip and the tie-rod up front, and out back the lugs were within an inch of the 90* bend inside the wells.
I planned ahead and also got some 1" bolt-on spacers from TrailGear to put on the fronts, these gave me 2" better track-width, still cleared the fenders easily, pushed me out 1" from the tie-rod ends and made the Beastie a dream to drive. I'm terrified to articulate her too much, but I can still drive down a dirt and gravel road, and she feels like a Cadillac. I only got the Trail-gear spacers because they're the cheapest, they bolt on, and a friend of mine runs them on his stock mini-truck axles with 38" tires on a daily-crawler - no bad bearings, no broken axles, no damaged knuckles... and he beats the snot out of his almost daily. (He drives the short route home over the granite mountain - no roads involved).
I ordered the 4.5" Safari Deluxe Suspension lift from Man-A-Fre... originally I was going to get the 4" kit from Downey, but at first they were blocking me because the Bilsteins were 2 weeks away. Then when I called back to say that I would wait 2 weeks, they told me the springs were 3 months out. WOW. They really don't want to sell me a lift. If I wanted to wait 3 months, I could easily call up ALCAN and get some custom springs made.
I know, I should have waited, etc., etc., but what the hell... I've got a decent lift coming, I'll play around with it, do some trails and feel them out. If I don't like them in 6 months, I will go ALCAN and sell my 4.5" lift.
Next up, waiting for the 4.5" lift...
