looks good
more
Is the floor wavy or is it the lighting?
Can you give me some help with regards to your shackle dimensions. I know the fronts are std. 40's and the rears are from the 55's. I was told by Freddy at MAF that the shackles I needed and ordered from him needed to be 2 inches longer than stock to provide a one inch life which when coupled with the OME suspension system I bought from him will arrive at a 2.5" lift. My concern is that when the shackles arrived and I look at there size they look huge compared to what I have seem on others guys rigs who are using a OME kit. I think the 40's were 2.75" stock and add 2 inches makes them 4.75" center to center of the bolt. The rear 55 size was 3.5" so add 2" and you should have 5.5" center to center. These shackles look huge compared to pics, which could be deceiving. I am referring to the anit-inversion type of shackle by the way. Thanks, Mark
Looks like a little block party, sanding with a block is sooo much fun.
You sand in the booth?
I think some body shops are dead against sanding in the paint booth, but in thier case they are flat rate shops and production minded.
One thing I learned last year from a body guy, when blowing off the dust you use your hand to feel and rub off dust while blowing. This allows you to feel for imperfections not seen by the eye and also dislodges heavy dust.
