So...I'm working through a build on my '76 FJ40( Family FJ Build : '76 40 Resto/Frame Off - https://forum.ih8mud.com/threads/family-fj-build-76-40-resto-frame-off.1241981/), and for various reasons, opted to replace the tub with a fresh 3/4 tub. The tub frame/sides were fair with some rust on the rear quarters, but the floorpans and rockers were pretty rough. Luckily, the firewall is pretty good except for some minor patching on the lower cowl where the fenders mate up. For better or worse, I bit the bullet on a HFS tub - didn't like the aluminium or glass options, and seemed like it a pretty decent tub, albeit you do pay for it.
That said...it arrived a little bit ago, and with the firewall now cleaned up, it seems like the tub is consistently about 1/2" too wide on the front half, making for a bit of a poor mate with the firewall. Neither have any real "give" in them, so it doesn't appear to be a flex/wiggle room type issue. I'm somewhat curious if anyone might be able to snip a few example measurements from their tubs, just to help get this sorted. Easiest would just be the door jamb/rocker lip-to-lip up front where it's welded to the firewall. Lip to lip in the back by the striker on the vertical would be interesting as well, but not sure if there's clearance to measure easily with the seatbacks.
My old tub was 61 1/2" lip to lip at the striker area, but the HFS tub is about 62". The lip-to-lip where the HFS would meet the firewall is 54 1/2, but my hunch is that it should be around 54" to fit up...
Currently working with CCOT/HFS, but also trying to garner what info I can in the meantime...
Lip to lip, firewall joint/weld - new tub:
Lip to lip, near door striker (vertical jamb) - old on left, new on right:
Set flush on one side:
Not so flush on the other:
