1MOA
For almost 12,000 for a 3/4 tub they should offer better support than what they showed you
Any update?To be clear/transparent, as mentioned in the earlier post, CCOT has at least offered a full refund, but no option for a return tub from them to replace it. Oddly enough, this has gone on long enough that I'm actually past the 60 day window for credit card claims, but given CCOT will at least give a refund, that seems somewhat moot.
My current take, given that finding (decent) steel tubs is not easy:
For some reason, the owner at CCOT has refused on (1) and (2), leaving me to decide on the two options under (3), neither of which are great options at this point.
- Ideal: ship this one back, and get a replacement HFS tub shipped that has the correct dimensions
- This is where it was heading back in Feb, but no longer an option for some very strange reason
- Secondary : keep this tub, with a corresponding discount/comp for having to address the demonstrated issues
- It seemed like shipping/freight was the concern...but this has also been blocked/denied
- Last: it's a tossup between
- taking the refund and the gamble on finding another tubs - they'll be cheaper, but have similar issues...and it'll push timelines out even more
- ...or sucking it up and fixing this one and taking the $$$ hit and moving on
I'm tossing on the full hardtop this weekend to get a feel for what impact the error has on the doors going up the B-pillar, and then will see what they have to say about the rather humorous "malo" markings on Monday...
Aside from this, how is the rest of the workmanship? Do you really think this is an anomaly? They owe you something for sure.I took some time over the weekend to install the full hardtop and set the firewall in place with clamps to test the front doors fitment for issues at the B-Pillar. With the floor pan jigged/pulled in to correctly the firewall, I could get enough door adjustment to get a decent door line on the B-pillar, so I can at least work with that. (If the doors didn't meet the hardtop, not much one can do to fix it...the floors are workable, the B-pillar...isn't)
I need to move forward, as I've got parts that are blasted/raw-steel waiting. I've had enough delays as it is, so I'll be keeping the tub and I'll be cutting the floor pans and fixing the body mounts that are off, for better or worse...I frankly don't have the luxury of time to ship it back and track down another tub from another vendor at this point.
I gave the info above to the shop manager, who found the "malo" markings quite interesting - but it's 100% in CCOT's hands a this point. I told them I can make it work, but the tub markings further support my case that it's a faulty/factory-second kind of tub, and it's on them to make things right at this point. I reiterated that both the sum-of-parts or the shipping-loss options should be more than fair for all parties, but it's in their hands...I may get nothing in compensation, or they might do the right thing and give me the sum-of-parts. Either way, I'm moving on, and the chips will fall where they may. I'll share the final result, but at this point I haven't heard back.
They should have an outgoing QA plan with the factory in South America. The company I work for purchases goods from China and we had a quality issue some years back. We fixed it and received a new order from the same customer, but they wanted us to be on site inspecting all the goods as they arrived. I made they point that if they get all the way to the final destination and have problems, we've lost. So I went to China and worked out an outgoing inspection plan and pass/fail criteria. Haven't had an issue since.As always, there's two sides to any story - but I'm definitely confused by the owner's response, it just doesn't make much sense from a business perspective...ESPECIALLY in such a small/niche market as FJ40s. I've tried to be pretty pragmatic and factual throughout, both with them and on here --- but apparently it didn't register.
The dimensions were demonstrated to be off, with suspect markings from the fabricators on the tub in the area where it was off. Those same measurements were crosschecked against other stock tubs, as well as their competitor (Aqualu).
And then the refusal to send a replacement tub on the notion of "it might just have the same issues" sends some pretty high red flags on QC. If you can't have good enough faith to send a replacement product to known/supplied dimensions, that doesn't give a great signal about their confidence in their own product.
Past that, he was ready and willing to work through a return and eat the shipping in both directions, which would've been $1100 at a minimum as it was originally $550 here to a terminal -- likely closer to $1250 or so as the return would've been residential pickup at this point. So, even if he didn't believe me and thought I was some cluesless goober that didn't know metalwork, why take the stance on poor customer service/reputation by offering $300 to cover the rework and having to cut floorpans on a *new* tub when he was already set to lose the $1100+?
It just doesn't make sense, at all. Either the product isn't what it used to be and lacks QC, or they're lacking integrity in supporting what they sell, or both...and neither is a good look.
You make a very valid point. Why is it, apart from volume sales that you can get body parts for almost everything except a Land Cruiser at a great price that fit perfectly but seems no matter what you get for a 40 has to be custom fit, if it fits at all and then you get issues like this that you spend a small fortune for a part that obviously is incorrect and the manufacturer won’t stand behind it. I have purchased a lot of parts from CCOT, and they have been great except for crazy long lead times, bit I may rethink anymore big dollar purchases. Hopefully, they see this and address it.Agreed - a simple spot-check jig on both sides (both SA and CCOT) would be simple enough to have, and would give some firm QC that things are a-ok before a tub moves on down the road, both from SA=>CCOT, and CCOT=>customer.
I argued this years ago with my PACOL FJ40 fenders that were off by 1/2" to 1". By the time you made them fit, you should have fabbed your own. I got the same 'let's re-order and hope for a better batch' speech.
You can buy Chinese fenders and hoods for many vehicles that fit perfectly for $69 (admittedly much higher volume) - but somehow it's ok that $500 patch panels and multi-thousand dollar bodies for Land Cruisers aren't even close? The only way to combat this is to boycott this junk and spread the word.
