- Thread starter
- #21
lostmarbles said:Best to ignore my verbal diarrhea on occasions DD. (It's a kiwi thing. ..... Just like my compatriot - Dougal, I also like to engage in baiting from time to time.)
I like things to be stock but I must admit that the "superglow" preheat system the factory installed on your truck does give trouble and it was an early step towards treating landcruiser owners as "impatient dummies". .... In other words, Toyota tried to speed up the preheating process, and tried also to take the control of it away from the person sitting in the driver's seat (by making its workings automatic).
So in your shoes I'm not sure which way I'd go either. (Stock or modified.)
Firstly
Looking at my info here I see your EDIC relay (aka Fuel Control Relay) should be part number 28590-57010. (Have a look and see if you find this number on it.)
This relay was apparently used on the following Aug 1980 to June 1985 12 volt landcruisers:
BJ40, BJ42, HJ47 (B, 3B and 2H engines)
(and also found on an Aug 80 to April 82 2B-powered 12 volt BB10 Coaster)
In your pm you asked about whether the relay from a HJ60 would work.... Well it appears that relay is 28590-56090 (assuming its a 12V cruiser) so, because the part number is different, I doubt it.
Secondly
That wire to the oil switch (that you measure 5V on) gets "shorted to earth" whenever your oil pressure drops below around 3-5 psi. In other words, your oil switch opens on rising pressure and closes on falling pressure.
(So if your engine loses oil pressure during a journey, that wire will become earthed and cause your EDIC system to stop your engine.)
Thirdly
Your EDIC relay is different to my earlier one and I've kept only info relating to mine. So I'm afraid I'm not much help in diagnosing whether yours is faulty or not or what each component in yours does.
If it looks fine, perhaps you should take a peak inside your EDIC gearhousing. At the top there you'll find electrical contacts. Grease or other muck sometimes gets in the way to stop them operating correctly.
It is these contacts that tell the relay when the arm has reached the "set point" dictated by the conditions (and thereby stop further power getting fed to the motor that would otherwise make it turn too far).
By "set point" I mean these three positions:
[*]Fuel shut-off (aka "stop")
[*]Engine run
[*]Overinject (aka "start")
Hope this helps
The EDIC relay model number you provided was correct. I heard from another thread that you can't get them anymore (one site quoted $445 and I didn't think that anyone in their right mind would buy that) but after looking at mine, I don't think it would be too hard to make one if you could find the schematics but I think mine's fine. I never saw the armeture on the exposed relay
I disconnected the EDIC arm and wanted to remove the motor. One bolt came out just fine but the other wasn't cooperating and I didn't want to snap it. I got the 2H manual now (thankyou manual threads) and in my spare time I'll read up as much as I can about the entire EDIC system. Thanks again
DD
PS: The attached pic shows the relay that never engages in red (I presume this is for when the oil pressure drops too low) and one of the other relays in blue engages when the key is turned
I don't know if this means anything to anyone but it might help in troubleshooting it. The pic is from another thread but it's the same controller (too dark to take a pic)
