If this belongs in the Newbie thread then please move it but I need some serious help. I am coming to the end of an 18 month rebuild and on Saturday afternoon I was overcome by the exitement and tried to start her. Ok motor turns over great but nothing. When I switch the ignition on there is an immediate click , the glow light on the dash comes on , same as the sedimenter filter light, brake warning light. After 5 seconds or so the glow light goes off and a few seconds later the glow relay clicks loudly ... nothing . I check the edic but the motor stays in the off position at all times. Eventually I suspect the edic motor and yank it off there :whoops: Long story short motor openened , brushes replaced etc etc , tested and motor is now fine but we leave it in the over-inject position.
With hope I put it back and also check the glow plug relay's earth- not good , so I give it, its own earth wire as the fenders are not yet back on the truck. I also check the body grounds of all the other relays including fuel conrtol relay, starter , pre heating timer etc. So before I connect the edic I think ok as I connect it, the arm should move to the Stop position - well it does not !
So I crank it anyway and sure as ever she fires into life first turn but my absolute joy is very short lived as I notice the edic is still stuck in the over inject position
. So I am still where I was on Sat unless if the fuel control relay is faulty or not getting power
As a noob I take my test light and aim for the fuses. All fuses are present bar the ones for the radio and lighter. None of the fuses are blown. On the bottom 3 (Egine, Heater and Turn-wiper) I get a good ground(-) light on the fuses and the fuse holders yet on the top 3 (Tail,Stop-horn and Head) I get nothing on either the fuses or the fuse holders. So I connect my test lamp to the neg to test for juice and now I get a definate light from the top 3 fuses but nothing from the bottom three
My biggest fear with this project was the electrics so I was carefull and meticulous to the extreme but it seems my worst nightmare is now a reality. Please help
. So I am still where I was on Sat unless if the fuel control relay is faulty or not getting powerAs a noob I take my test light and aim for the fuses. All fuses are present bar the ones for the radio and lighter. None of the fuses are blown. On the bottom 3 (Egine, Heater and Turn-wiper) I get a good ground(-) light on the fuses and the fuse holders yet on the top 3 (Tail,Stop-horn and Head) I get nothing on either the fuses or the fuse holders. So I connect my test lamp to the neg to test for juice and now I get a definate light from the top 3 fuses but nothing from the bottom three
