Extreme (heat or cold) environment, reduce life of rubber (T-belt). This is why we see some OEM belts, very nasty at 90K/9 year, yet others are fine at twice the mile/years
98-05 non VVT has no proven history of interference in ih8mud. Many example in mud of T-belt break under load, with out valve or piston damage (interference). But will need a tow, as engine will not run.
06-07 VVT 4.7L 2UX, is interference. Examples in mud. T-belt break, require engine replaced.
This 2005 non VVT 4.7L 2UZ, was brought to me, after a T-belt service. It was diagnostic needing a new engine. I found, Cam sprocket spun on camshaft. It was believed it spun, a little more out of faze, with each start-up. Failing to run after 3rd or 4th start-up. Which means at least one cam out of faze/time, in multiple positions as engine ran and then just cranked trying to start and the crank to do a compression test on all 8 cylinders (~20 minutes of engine crank). Sprocket landed in the end on cam shaft, about 180 degrees off the mark. Engine was fine once sheared knock pin replaced, and cam bolt torque on!
forum.ih8mud.com
Timing belt job just done. Blown engine or savable? This is interesting guys!
Happy 2020 all. Well, I spent last day of 2019, inspecting a 2005 LC w/~200K, that was towed to me. That had a Timing Belt installed a few days before coming to me Let me know your thoughts: Blown engine from interference or is there hope? Also what do you think happened? Skip story and go...
forum.ih8mud.com
