2008-2018 Radiator Failure and Public Service Announcement (22 Viewers)
These typically get 1/8-1/4" longer toward the driver's side before they fail. Based on that I'd predict you having quite a bit of time before it fails even if left alone. Multiple thousands of miles, if not tens of k's.
But yours would be a great candidate for a preventative patch to strengthen the area. Lots of guys do this and basically prevent the failure entirely. Some for close to 100k. The critical detail is to do it as early as possible, definitely before it starts leaking. So that's a good option and you should be able to get it done and tested before your trip.
If you do decide to let it ride, monitor it closely for growth.
Thanks for the input. Evidence of how long the crack usually gets before failure even if anecdotal was pretty much exactly what i was looking for. I have debated the patch for a while and decided to avoid it during the warranty period just in case it started to leak and I could get it fixed for free. With 1200 miles of warranty left its unlikely that it will start to leak but if it doesnt then waiting for warranty to expire likely won't change the patch effectiveness either.
The diabolical super villain in me has also debated if I could mechanically flex it in such a way to make it start leaking before 75k and score a free replacement and I could avoid the job myself. My local service advisor has been very good to me with warranty claims but a non leaking crack I doubt he could get a replacement approved before it starts leaking.
I'll probably let it be until the warranty expires then patch while I await the next part sale and then do the radiator as well as the other common 100k-ish parts myself at the same time. That will be a job the level of which I've never done before but with all the posts and tutorials on here I imagine I'll get it done with minimal problems.
@bloc when replaced your radiator for the third time. Did you do water pump and tensioner etc?
I did the pump with the first radiator around 105k, both pulleys around 150.
Yours won't fail in the next 1200 miles, but I'd go ahead and get the OEM radiator on the 25% off sale. Serra Toyota (Decatur, AL) does a great job shipping carefully and does so for free. Have it on hand for when you need it instead of betting on future parts availability.
Fair point. No sense waiting to order the parts. I just need to compile the all encompassing parts list for a 2018 that I should change at 75k (if any) while I have the radiator out.
Just picked up a 2013 200 with 77k miles, part 5038-931-42703. How am I looking? Planning a coolant drain/fill at a minimum, is it worth replacing the rad while it's at the dealer?
Just watch it, I take a peek at mine whenever I'm under the hood. I have the new style radiator in storage, but the old style in my 2016 is perfectly fine for now.
If you have the part what is the benefit of not installing it? Unless you’re paying for labor? The new one should have a very long service life without the cracking issue. Why wait and risk losing your coolant and overheating the motor?
My read is it's not likely to be a catastrophic issue, as most here notice the coolant build up well before overheating. Since I check regularly, I've decided to wait until the next coolant change is due in about 20k unless the radiator goes first.
I bought a new radiator during the last sale. I’m going to install it even though the one in my ‘17 is in good shape. I take my LC on trips lasting many 1000s of miles and many weeks towing. It would be silly to have a new in the garage and have a crack develop on, say, the Icefields Parkway in BC. However, I’m keeping the old one in my storage shed. There’s a want ad in the forum classifieds where someone is looking for a LC and one of the criteria is having the old style radiator still in it so they can be sure there was never a blown radiator and overheated engine. If I ever sell, having the old one could give a savvy buyer some extra peace of mind.
