You didn't just imply it as a primary contributor, you TYPED it rather clearly!!Regardless, you make good points.
Ah, that was in reference to the material degradation specifically, not the overall failure.
Assuming those longer trips would also indicate higher average driving speeds, doesn't this also complicate your "time at temperature" argument as well as my "higher cycle" argument?
I'm actually really curious to see what the inside of the upper tank looks like whenever I swap it out, likely before next summer. If it isn't material degrading, or stress cycles, why would it fail this quickly? The fact that a lot of those miles tend to be through north texas during the summer? Even straight temperature doesn't make sense, as these are mostly unloaded miles. Others get many more miles with a larger percentage of those towing heavy.. I do almost none of that. I don't even usually drive fast on these trips.. ~75. Marginally taller tires but no other aero consequences increasing HP demands..
The picture of the now-yellow radiator inlet was from a vehicle driven mostly in Dallas, IIRC.
You should try my Fix 2.0!!....
All that would show is when it has actually started leaking, not further crack propagation from when you applied the patch, to tell whether it's helping or not.
Even with a couple people reporting their patches are holding, as stated with my likelihood of being far from home when it finally does let go, I'll just be putting a $288 new OE radiator in it before things get hot. Should only take a few hours.
