I do complet 12 qt flushes all the time.So... bubbles apart, a one-step complete drain is then possibe ? Can you run the engine until almost all of the fluid is out ? (converter, hoses, radiator, all except strainer and pan, which then will have to be unbolted in order to get the remaining 3 liters out).
Then after refilling, the system will have some bubbles. Is this a real problem besides having to shift through all gears to remove/purge all bubbles ?
I find this much easier and cleaner than having to mix old with new fluids in several steps. But I don't know whether it is really possible or not.
TIA.
After draining pan measuring what comes out very carefully and refilling pan plus 1 qt.
Connecting a hose to return cooler nipple (top RH side of radiator), and run to catch can marked in 1 qt sacraments. I then run engine to pump old out, as I poor in new in. I measure what comes out very carefully. Engine running, transmission pumps out faster than I can add new in. So I stop engine, as need so that I don't run transmission pan low.
Done correctly you'll never run pan low. The only air bubble is a tiny one, from disconnecting & reconnecting return AFT cooler hose. Which is not a problem.
