Current:
After searching for a year, I finally picked up a 06 LC100 last week. The carfax showed 2 owners and was clean of accidents but was lacking some maintenance records. The vehicle showed signs of maintenance being done (stickers in the engine compartment, newish brakes, etc.) so I felt like I could take a chance. I used the skimpy carfax report and a pre-purchase inspection by a Toyota dealership to get the price down to a number I was happy with.
Truck has 141k miles on it.
Since picking it up I have had the water pump, timing belt, accessories belt, thermostat, and all affiliated gaskets changed as well as coolant flushed. It was leaking from the high pressure power steering hose so I had that changed and the system flushed.
I kind of wish I would have done that maintenance myself, as I might have dug a little deeper with the preventative maintenance (tensioners come to mind), but I got a pretty good deal on the vehicle so used some of the cash I saved to just get that work done at a dealership.
Maintenance Performed
141,200 Timing Belt (Done 6-9-16)
141,200 Water Pump (Done 6-9-16)
141,200 Serpentine Belt (Done 6-9-16)
141,200 Thermostat (Done 6-9-16)
141,200 High Pressure power steering hose (Done 6-9-16)
141,200 Power steering fluid flush and fill (Done 6-9-16)
141,200 Coolant flush and fill (Done 6-9-16)
141,200 Remove running board (Done 6-11-16)
141,200 OEM Toyota oil filter (DONE 6-11-16)
141,200 mobil 1 5w30 (Done 6-11-16)
141,200 Airfilter (Done 6-11-16)
141,270 Rear Diff Mobil1 75-90 (DONE 6-18-16)
141,390 Transfer Case Mobil1 75-90 (DONE 6-23-16)
141,390 Front Diff Mobil1 75-90 (DONE 6-23-16)
141,410 Lube Axles used Moly on driveshaft, lithium on U-joints (DONE 6-24-16)
141,850 Heater T's and hoses (Done 7-7-16)
142,000 18" K02 (Done 8-10-16)
142,000 ARB Awning (Done 8-10-16)
142,000 CV Axles inspected, seem good going to leave alone for now
147,000 KROWN Rust Preventative Treatment (Done 12-3-16)
147,600 Oil change 7qt. Mobil 1 5w30 (Done 3-27-17)
147,600 new oil filter 90915-YZZD3 (Done 3-27-17)
150,000 Dissent Bumpers front and Rear (Done 4-4-17)
154,600 Oil change 7qt Mobil 1 5w30 (Done 8-19-17)
154,600 new oil filter 90915-YZZD3 (Done 8-19-17)
154,600 Lube axles using lithium on u-joints, moly on driveshafts (Done 8-19-17)
154,700 Tires rotated
154,800 AHC fluid change (Done 10-28-17)
154,900 KROWN Rust Preventative Treatment (Done 11-15-17)
155,000 Windshield replaced and rust removed and repainted (Done 11-30-17)
HIH8 PREP BEGINS
155,753 New Muffler (Done 5-30-18)
155,753 OWL Expedition Media Mount installed (Done 6-14-18)
155,753 CB and Antenna installed (Done 6-14-18)
155,753 Both CV Joints Rebooted (Done 6-14-18)
155,753 Wheel Bearings replaced using Cruiser outfitter kit (Done 6-14-18)
155,753 New Front Sway Bar End links, bushings, hardware (Done 6-14-18)
155,753 New Pass side Needle bearing, bushing, seal in knuckle (Done 6-14-18)
155,753 New Drivers side inner Knuckle Seal (Done 6-14-18)
155,753 Clean and painted Knuckle Dust covers and replaced Oil seals and gasket (Done 6-14-18)
155,753 Upper and Lower Ball joints rebooted, both sides (Done 6-14-18)
155,753 POR 15 front lower control arms and Misc rust spots (Done 6-14-18)
155,753 King Springs installed (Done 6-19-18)
155,753 New Rear Sway Bar links, bushings, hardware (Done 6-19-18)
155,800 New Battery 5 Year warranty with AE Autocare (Done 6-24-18 AE Autocare)
155,800 High AC line replaced Pass foot-well to muffler with OEM piece and low side O-ring replaced (Done 6-24-18 AE Autocare)
155,800 AC Recharge (Done 6-24-18)
158,180 Oil changed - Mobil 1 5w30
158,180 Oil Filter changed - OEM Toyota
158,180 driveshafts lubed
161,800 MetalTech 4x4 Sliders installed (Done 5-15-19)
161,814 Oil changed - Mobil 1 5w30 (Done 5-25-19)
161,814 Oil Filter Changed -OEM Toyota (Done 5-25-19)
161,814 drive shaft and u joints lubed (Done 5-25-19)
167,657 Tires rotated (Done 5-2-20)
168,000 V-Line 2 installed (Done 5-9-20)
168,000 Replaced front door speakers (Done 5-10-20)
168,570 Oil changed Mobil 1 5w-30 (Done 9-7-20)
168,570 OEM oil and air filter changed
168,570 drive shafts and U joints lubed (Done 9-7-20)
168,570 replaced battery with optima red top (Done 9-7-20)
Still on the to do list:
AHC rebalance after new bumpers
Retrofit cabin filter box and filters
Once I am done with the baseline I would like to get:
I have reached out to the 3 forum members who do parts to get the ball rolling on the above maintenance.
Am I missing anything? I have been doing a ton of reading and think I have my basses covered. I will take some pictures tonight, but imagine a pretty clean stock black 100 series.
HIH8 PREP BEGINS
