2000UZJ's big HID thread - what, where and how (2 Viewers)
Buy some double sided tape? Or zip ties.
Quote:
Originally Posted by Mxndrnks
It did not come with double sided tape like 2000UZJ's did or the bracket that AATLAS1X said his came with. So, I need to figure a way to secure these... Any suggestions?
the first set had the brackets, the 2nd and 3rd did not. I used wicked double side tape to sandwich one on the back of the other that had the brackets and then belt over the tab and it bolted strait to the inner fender support bracket. When you remove the head light and blinker you will see the brackets and then for the fog ballast I used double sided tape (I didn't want to but then will be fine and never move) and stuck them on the inside fender liner behind the battery through the head light hole and the same on the other side. I also slathered Toyota Die electric grease in every fitting to fight moisture.
Thanks for the link:)
They only offer a couple different colors 3000k and then it jumps to 6000k and up. 3000k is too yellow and 6000k is too blue nothing in the middle:mad:
there is NO blue in 6000k
they are day light, no hint of blue what so ever as I don't want to look like a jack off kid.
edit
--Specification--
Color:
Diamond White, 6000K Color Temperature
edit
--Specification--
Color:
My 5K is has blue when you look directly at it, they are the 55W so the color is washed out a bit (so more like a 4500K color). I would say the 6K 35W would be blue.
edit
--Specification--
Color:
I work with Kelvin 5 days a week if the temp is an accurate 6000k it has blue. Accurate is the key word
Friend of mine had 6000K HIDs in his FJC, they are definitely blue......I have pictures somewhere if anyone cares to see them.
I have multiple personalities and my friend says they are white with NO blue. So :flipoff2:
Plus the bottom right says USE ONLY AS A GUIDE TO ARGUE ON THE NET.
FJC with 6000K HIDs......Id say they are definitely blue
Phil,
The ones I bought, there is no blue.
What was described in the ad was correct for my results
Shane
Phil,
Shane
No argument from me I believe you know the difference between blue and white.
I just was inquiring.....thinking maybe Shane is a closet tuner:hhmm::flipoff2:
No worries and glad to see they are indeed white
