- Location
- United States
2000 Toyota Land Cruiser
225,000
Tan Exterior
Tan Interior
Selling my 2000 Toyota Land Cruiser. We are the second owner of this vehicle, with it being a California truck for the entirety of its lifetime (passes emissions with no issue and tags current through November). It is in good shape, apart from a few things. Motor and transmission runs smooth. The interior is in good shape and the leather is in good condition. It is full-time 4WD. It is mostly stock on the outside with some thoughtful modifications inside; built for camping. Garaged for much of its life. The offroad trails its seen is more fireroad than hardcore, so its not beat up at all. Its only started to see light trails in the past 20k miles.
Features:
V-8 4.7L Motor
Automatic Transmission
Tan leather interior w/ heated seats
Rear climate controls
Factory Keyless Entry with Alarm
Tow package (never used)
Hi/Lo transfer case with center locking differential option
Modifications:
Nitto Terra Grappler all-terrain tires (285/75/16 size) with matching spare
Running boards removed for additional clearance and torsion bars cranked
National Luna dual battery system installed w/ second battery and in-cab monitor/control
Blue Sea fuse block in cab to accommodate future electrical expansion (aux battery)
Blue Sea USB power outlets added to 1st and 2nd rows to power devices (aux battery)
Dual LED light bars (white and red) installed on back hatch for light when camping (aux battery)
Dual locking ARB Drawer System (1 fixed top, 1 sliding top) w/ side fitment kit
Engel MT45 12v fridge mounted to ARB drawer slide (aux battery)
Yaesu 7800 dual-band ham radio w/ detachable faceplate (aux battery)
Diamond dual-band ham antenna
Labrak antenna mount (right side)
All wiring and cabling run cleanly throughout the engine bay and cab
Cargo Net behind 2nd row
Pfran LED interior light kit installed
HIR bulb headlight and high beam upgrades
Kenwood stereo head unit replacement w/ Bluetooth and handsfree calling
More recent service history highlights:
180k service performed (by Alternative Automotive) with new timing belt, new water pump, new radiator, fluids, valve cover seals, etc
Motor replacement (by Alternative Automotive) at 200k due to heater hose fitting failure
CV Boot (right) replaced as needed and front end toe checked (by Alternative Automotive) at 207k
Brake fluid flush and rear brake pads replaced at 207k
Full service history available upon request.
Known issues:
Door actuator switch in cab does not activate the power locks, but key fob remote does activate locks
CV Boot (left) needs replacement
Tick from manifold is lightly audible
Rear bumper cover was damaged in a parking lot, but underlying structure and bracketing is solid per the insurance appraisal. I have been searching for a replacement cover since it is only cosmetic. It does not affect drivability or accessing the rear cargo area or drawers.
Various minor dings, paint fading slightly in a couple areas (I try to keep it waxed to protect), and some slight trail pinstriping
I had not originally planned to sell, as I was only starting to thoughtfully build this from the inside out and beginning to enjoy it, but I have some family things that are a priority.
Thank you for your interest.
$9600 (negotiable within reason)
Located in North San Diego
225,000
Tan Exterior
Tan Interior
Features:
V-8 4.7L Motor
Modifications:
Known issues:
