SOLD TX: 2006 Toyota Land Cruiser UZJ100 **REDUCED PRICE**
Status
Not open for further replies.
Houston
Year
2006
  1. 100 Series
Houston, Texas United States
Mileage
235110
Color
Blue
Asking $16,000 **REDUCED PRICE**
235,100 miles @ 2/26/2025 (may go up slightly)
Pacific Blue Mica with Tan interior
No AHC
Clean Title
Clean Carfax (see photos)
No Accidents
Modifications:
Ironman Front Bumper, no winch, but cradle installed
LED Lowbeams retrofitted to OEM Housing
Gamiviti Full Expedition Rack
Ebay Snorkel with Sy-Klone snorkel head (cracked/repaired after it got knocked off in car wash)
TRD Rock Warriors with 285/70-17; Full matching spare included
TRD flat center caps + 1.25” Bora Spacers
TRD domed caps (currently fitted, small 5mm spacer in front)
Trail Tailor Sliders
Trail Tailor Front Recovery Point
Tough Dog 41mm Front/45mm Rear Adjustable shocks (1/2021)
Tough Dog rear medium springs (1/2021)
Trail Tailor Front Upper Control Arms (1/2021)
Trail Tailor Extended sway bar end links (1/2021)
Trail Tailor Differential drop (1/2021)
Delta Vehicle Systems Panhard Drop Bracket
Extra parts:
New OEM fuel filter
New OEM Toyota Fuel pump assembly
Denso 02 sensor
Differential breather hose kit
Extra set of Depo replacement headlights with H1 HiD kit/relay harness/ballasts/ignitors
Miscellaneous other stuff I find in the parts bin that’ll go in the back of the truck
Recent Maintenance:
Radiator @ 233,000mi
Rebuilt Brake Master Cylinder (Andy Le) @ 234,000
Full synthetic Oil change/Driveshafts + Upper Control Arm greasing every 7,500 mi @ 234,500
Valve cover gaskets/Spark plugs (1/2023)
The "Run Down":
I think this rig is pretty clean. There is some surface rust on some of the modifications (rack and sliders) from the coatings/finishes rubbing off, but the undercarriage is pretty dang clean. I’ve owned this truck since 2016 and purchased it off another local Mud member. It’s served my family well, but we’re in the season of life that we’re better off in something that gets better gas mileage and is easier to get in and out of. I get compliments on it all of the time even though the hood needs a repaint due to clear coat failure and other dings/scratches, etc. There are a couple of dents that could be removed via PDR, and more sizeable dent caused by my dumb self when I was trying to remove the 270 awning by myself. It’s almost 20 years old, so although it cleans up pretty well, it’s definitely a “10 footer.” All buttons work; however the buttons on the lower part of the center stack need to be pushed multiple times if they haven’t been pressed in a while. I just replaced the lower seat cover on the driver’s side using Wolfman’s Auto’s piece. I also just recently noticed that the roof liner is beginning to bubble/sag on the drivers side, 3rd row area (see photos). The rest of the interior is in pretty good shape. The leather is a little dry and could use some TLC, but no other tears or rips. Some staining in the carpets, but might be able to be removed via steam or hot water extractor. The tires have pretty decent tread, but the fronts are a little chunky/choppy.
I’ve kept up with most maintenance items myself and had some stuff done by local Toyota specialists; however, it’s going to be coming up on a TB/Water Pump/Tensioner replacement somewhat soon. I last had it done @175,000 miles in 2018. The passenger side front inboard axle boot is leaking a little grease, so a CV reboot might be needed. I don’t see any tears or rips in the boot, so I can only guess that the clamp isn’t on as tight as it could be. They were last serviced in 2022. At the same time, I’d probably go ahead and do a full service on the front hub/brakes. Steering rack is also weeping, but I haven’t had to add any fluid, and I check the reservoir every time I have the hood up. Recently, I’ve been getting an intermittent check engine light that indicates one of the 02 sensors might be on its way out (replacement 02 sensor in the extra parts bin).
That’s all that I can think of at the moment. I’m sure I’ll remember more stuff about this truck when I talk to prospective buyers. Car is located in Cypress, TX (suburb of Houston). Please feel free to reach out with any questions about the car at (Seven-onethree) 9-Zero-six-EightySeventy.
Extra pictures
Interior/Engine/Exterior Damage
this will go in seconds......
I'm happy to bump up the price! I just figured, someone could use it the way it's intended and maybe have some room to fix the cosmetic stuff and address upcoming maintenance. I figure, if you DIY all the maintenance, you could probably do it for another $2-2,500? We made some fun road trips during our ownership, and I'll never forget attending HIH, but nowadays, it's soccer practices and trips to the beach.
I can relate on all counts.... I prefer cheaper price and fix the things on my own.... and then yeah, as much as I love these rigs in built form, for the driving we do - practices and beaches - the built this way is not used ot its potential, or becomes inconvenience in times. My 07LX is almost stock this time.
Bump for reduced price
Status
