200 Series Tire and Wheel Size Database (10 Viewers)
I'm running 275/70R18 Nitto Ridge Grapplers with 1.25" spacers on a King 2.5 suspension (should be about 2.5" of total lift) and had much more rubbing than expected (full lock in reverse). Both of the front flaps have now been removed; the rubbing on the rearward flap was very slight and removal fixed it completely. I also removed the small front postcard sized one as well, but still had a noticeable rub so I broke out the heat gun which solved it for me. It wasn't the end of the world, but I just don't want to listen to my tire abusing my fender liner every time I back out of a parking spot.
Interesting thread. Is there anyone here that goes places where they sometimes need to put on tire chains? I live in the south, but go skiing enough that there is no way I would go with taller tires (70), because I want to be able to run chains when I have to. That is why I am planning on going with 60 or 65s instead of 70s. I have 285/55s now.
Get a spare set of wheels/tires for snow trips. Get someone's factory takeoff wheels + blizzaks = win. Plus you're apparently only supposed to put chains on the rear tires in the LC according to several threads on here.
@scottm - I am about to have a set of 1.25” Spidertrax spacers available. I was running the same tire size as you (275/70R18) and these spacers were perfect. I went with new wheels and bigger tires, and no longer need the spacers- let me know if you’re interested in the 1.25” size.
Pic of my LC with these spacers and your tire size.
Did you need spacers to avoid hitting kdss? I’m planning on running 275/70/18s in stock 18” wheel as well.
@Flinthills - I have a set of 1.25” Spidertrax spacers for sale in the classifieds section if you’re still looking.
Here was my truck with 275/70R18s, the 1.25” spacers, and a lift.
Are you running 1.25” spacers for all 4 wheels? I’m interested in this same/similar set up. But for 2010 land cruiser.
And you run spacers because you like how it looks for your tires to stick out away from the truck a little and give a little whider stance?
For me personally aesthetics are a major component, but IIRC running a larger/taller tire effectively changes the scrub radius and a spacer (*on stock offset wheels) can help get that back into check
I like the factory BBS wheels too much to change them, otherwise I'd buy wheels with a lower offset like +25 or +30; as it is right now they don't really poke, they are about flush with the side of the fender
For me personally aesthetics are a major component, but IIRC running a larger/taller tire effectively changes the scrub radius and a spacer can help get that back into check
oh, ok. thank you. I had never heard of scrub radius before. I have been running 33s on my FJ60 for 20 years (original tires were 28s). I googled scrub radius and see what you mean. How does going to a new tire size, and I suppose yo mean from a 60 to a 70, how does it manifest itself when the scrub radius is not compensated for with a spacer?
Yeah I'll be honest too it was never a concern for me with my previously lifted 4Runner, but I have found the LC forums and MUD in particular to care a lot more about technical details of builds than other forums.
I'm also not the most technical person to ask for great in depth explanations, but the basic answer is that improperly setup scrub could manifest as tire wear and squirrely handling
You can use this calculator to determine changes in scrub radius given different combinations of tire size and rim offset. For instance, if we start with the OEM tires and rims (285/60R18, 18x8 with +60mm offset) moving to a 285/70R18 tire and a rim with an offset of +25mm (or the OEM rim with a 1.25" spacer) then the scrub radius will increase by 26mm. It is generally agreed that keeping the change in scrub radius to less than 10mm is optimal, but often this is not possible.
Rim & Tire Size Calculator. Custom Offsets - https://www.wheel-size.com/calc/?wheel1=285-60-18X8ET60&wheel2=285-70-18X8ET25&fcl=50mm&scl=50mm&wcl=30mm&sr=0mm
Yes, I ran 1.25” spacers on all 4 wheels. I primarily did it for looks. The OEM wheels were too tucked in for my taste - looked like a fat lady with skinny legs. I put spacers on almost all of my cars to bring the wheels/tires flush to the outer edges of the wheel wells.
I no longer need the spacers because I put on 18x9 +25 offset wheels with 305/65 tires - and my truck has a solid stance. Spacers are a good way to fix the “too tucked in” problem with the factory wheels.
Ditto. Likely changing out for aftermarket wheels on ours soon as well.
Are the clearance parameters already present in the link specific to the 200? 50mm, 30mm and 50mm..I've been trying to advise my cousin on wheel/tire choices for his somewhat recently acquired 200 and have been looking for a calculator like this.
Question for the brain trust:
I'm eying the Toyo Open Country AT III in a 35x11.5x17 on an LX. Seems like about the biggest I can go diameter wise without BMC (hopefully) and I prefer the extra sidewall of 17's over 18's.
In shopping for 17" wheels, there are a handful of cheap 17x8.5 options available on tirerack with fitment for the Tundra with +35mm offset. I've read +25mm is ideal for larger tires. Do you think +35mm would work given the 8.5" rim width and 11.5 tire width? It's a 200% price jump to the next wheel with +25mm offset.
+35 is actually “more ideal” than +25 assuming you are optimizing for suspension geometry and not looks.
