So do we believe that 285/65r18 don’t rub w/ OEM front end spacers? If I’m trading, tomorrow is the day.Discount tire does offer trade in value and it's not bad..
Seeing you're in Atlanta there's discount tires around you
Will not rub on stock LC.So do we believe that 285/65r18 don’t rub w/ OEM front end spacers? If I’m trading, tomorrow is the day.
Probably need spacers in the 3/4 to 1.25” range. You can run dtracs in 275/65r18 no spacers. I have done that no problem but they are pretty close to the uca.Hello everyone, I just purchased a 2020 HE, and I am die hard Duratrac lover. Had them on my T4R, and my Tundra. Repetitive sets. They last forever, handle well on and off pavement, snow, and are relatively quiet. I will keep the stock suspension for now (wife gripes about the climb in). Adding ARB drawers, Bud Built skids and sliders, and maybe a front and rear bumper in the future in combination with at least a two inch lift when the bumpers are added. On the tires, I am thinking 275/70/18 and keeping wheel. Any thoughts or notion of rubbing?
33x12.50x18 toy MT. OME lift with Total Chaos UCA swap. Speedo is on point as it was calibrated for 275/70/18 tires which were slightly off. MPG suffered a little with weight and resistance. Love the look and just wasn't committed to the 35s.
Would it have fit with them off? Did it rub anything else?I stole the wheels off my 100 this past weekend...17x9 +25 with 295/70/17 Toyo R/Ts. It rubbed on the mud flaps and I wasn't ready to hack it. Back to the 100 they go lol.
Most likely fit with them removed. I also removed the air deflector in the front of the wheel wells and formed the liner.Would it have fit with them off? Did it rub anything else?
OK thanks. Did not really want to go with spacers if I could avoid it. Was hoping also not to have to go to the pizza cutter look, but but at 275/65/18, it would only be about 14mm difference I guess.
Wheels and tires going on today. Heritage Edition Bronze wheels (thx @Eric Sarjeant) - Read this thread extensively, ultimately went with Toyo Open Country R/T's in a 265/65/18 size. Wheels have been test fitted, no rubbing either direction at full opposite lock. More than a finger's clearance to the UCA's. Will circle back with better pictures once everything is done.
View attachment 2154886View attachment 2154887
Did you mean 285 or did you intentionally downsize? Those new Toyos look great in any event.
