Either set should be fine. You have exceed 33” O.D. or radically change the offset to have an issue. I have 275/60/20 with NO rubbing even in low mode.
Thanks much, leaning towards the '13 set so I can slap my center caps in there....
YesRecently built up my 2017 with the Ironman Pro Foam cell suspension, Total Chaos UCAs, and 17" Method Wheels with 285/70/17 BFG KO2s.
I currently have the original 18" stock wheel and spare. Searched all over the forum for guidance....
Would a 285/70/17 fit in the spare tire bay?
So with the 3-day weekend, I finally had the time to hit the wheel wells with the heat gun. Pushed them in about an inch or so and... the rub is virtually gone. There's still a *tiny* rub on the KDSS bar on full lock in both directions, but you've really got to be listening to even catch it.
In retrospect, I probably would have gone with a 1" spacer vs the 0.75". That likely would have eliminated the rub on the KDSS in both directions. Live and learn. Overall, I couldn't be happier with the outcome. I think the RGs in 285/70s really are the perfect tires for our rigs, at least on stock wheels and lift.
Do I wish we could go 35"? Absolutely. But this comes pretty damn close without (most importantly) making significant modifications.
Swap away. Ran stock 18” and that tire size here for about a year. No problems.I bought a set of used TRD Pro 18" wheels that came off Tundra 2014. They came with Bridgestone Dueler H/T D684II, P275/65/R18 tires. I plan to put them on my LX570 2010. It looks like the same exact setup as @MScruiser got on LC in the database. Is there anything I need to worry about, or should I just swap my OEM 20" and that's it?
Also, how is Bridgestone Dueler on the snow? The reviews are not so great, but I want to give it a try in Colorado for a few weeks, before I spend more money on something like BFG KO2.
Forgive me if you answered this earlier, do you have a lift installed?
Who makes the snorkel?Hi
What do you guys think
37X12.5R17View attachment 2042914View attachment 2042915View attachment 2042916
That is the best looking snorkel I’ve seen.
Mine is so much more obnoxious...
monsterservice.pro
Anyone running 285-75-17 BFG A/T’s on Icon wheels with standard OME (not BP-51) lift? Major rubbing? Really hoping to run close to 34” BFG’s instead of the 285-70-17’s which seem to fit fine.
That is an odd, and incorrect statement.
