Media 200 series picture thread (11 Viewers)
Photo/Video/Audio threads
I like the roof basket...if it wouldn't render parking garage (Starbucks drive through line?) even more useless I would put it back on.
Report back on the lean @MRego , but looking good. I'll have to measure mine later to check.
Ah @das100 and I think alike. I still rock my roofbasket with pride :cool: . I am fortunate to have ample space at work and my home garage is also high enough. Haven't thought about the Starbucks line since acquiring a proper expresso machine for my morning lates. Saving tons of money. 😅
Yes, please report on your measures. I am measuring from the top of tire to the fender to try and isolate from the ground, but even then if the surface is not even enough there will be some influence. This is what I got measuring today. Rear Pass 6,5; Rear Driver 6; Front Pass 6; Front Driver 5,5. So, looks like I am getting half an inch of difference. I was told by the shop that up to half an inch is normal for 200s but they will have another look next week.
The pic below is at my work parking lot where the ground is more even, and I guess you can see a tiny bit of lean if you reaaaally look for it.
And here is a side view. I like that I still have a tiny rake.
coffee is against my religion. I have never purchased anything at starbucks.
Sheesh, It's the thing I most look forward to every morning. Thousands of dollars tied up in espresso gear. 🙈 Someone should make "coffee and cruisers" a thing. I'd sign up for that.
After being photo-bullied by DAS several times here, I bit the bullet and installed the WD pre-collar lift in the front of my HE non-third row. Amazing how much 2 to 3 inches makes a big difference for these trucks. I am running 285/65/18s on the HE wheels. Also installed spidertrax wheel spacers to avoid rubbing. I think I am now set for a good while without any mods (wife made me say this :rofl: ).
I can see the need for UCAs from here (camber)
A few pictures from doing the White Rim trail last week in Canyonlands NP. Beautiful area!!!
We’ve been wanting to do white rim but didn’t think we could tow through there… any issues? If I’m not mistaken there is one spot with a fairly low overhang that I thought may give my trailer trouble but then I read somewhere no towing so just abandoned the towing related research.
Small tire gang! I'm still running them on mine (same truck) Bilsteins were on back order last summer when I was shopping then one thing led to another (other projects/expenses). Yours looks good, mine is in need of bath/detail.
I just recently did the WD 3/1 and decided to retain the OEM shocks because I'm very happy with the ride of OEM. Tires are next on the list.
Good idea. I honestly think 33/34s are the perfect size for these trucks. I just spent a week in back country NV/CA and the stock suspension is pretty frickin awesome.
