I haven't completed this yet, but here is what I have so far. Hoping this may help someone else. I'll update once completed.
My research has indicated that the 40 section of the 60/40 split can be removed.
It is advised that the seat is in the "up" position and off of the rear latches. The front facing bolts should be removed first (the plastic trim cover should pop off but be careful, it likes to bend).
The second step is to remove the top facing bolts (under the front of the seat).
Third step is to disconnect wiring harness (if present).
You will most likely need a Toyota Part No.: 09843-18061
SRS CHECK WIRE to prevent airbag warning lights.
I have good intentions of making a video of this process.
