Hey everybody,
My 2009 Landcruiser has roughly 200,000 miles on it. I’m looking to have the fuel Injector serviced due to what I believe to be leaky injectors, causing long difficult warm starts. I’ve recently changed out the MAF sensor all the O2 sensors both speed sensors and the PCV valve as part of preventative maintenance. Also the fuel pump was starting to fail, so that’s been replaced.
The long starts have been on and off for the last six months or so, but ever since getting the new fuel pump it seems to be more consistent. This seems to makes sense given the old fuel pump wasn’t pushing the proper pressure and now that the fuel pump is minty fresh I believe one or more of the injectors are leaking after shutdown, specially if the car has run for a while. The unmetered fuel in the combustion chamber could be creating an overly rich environment upon restart. Once the car starts, it runs flawlessly - absolutely no problems. I have no codes check engine lights or anything at the moment.
It seems like pulling the injectors should be pretty easy however I can’t seem to find any write ups or YouTube Videos specifically for the 5.7L LC 200. Knowing the tundra runs the same motor I’ve reviewed those however, the instructions I find for the tundra doesn’t seem to involve removing the intake manifold whereas anything I can find regarding the LC 200 does require removal of the intake manifold.
Can anybody lend their experience or advice on removing the injectors. I plan on sending them out to RC engineering for full rebuilds.
Any help would be much appreciated.
Thanks
Thanks
